dual map question
Old Dec 1, 2011 | 05:32 PM
usnevo8's Avatar
Originally Posted by fwd_josh
i have the single pod on the column now, and having a CEL or 2 has motivated me to move my gauge off the steering column eventually.
i broke down and got the groupe s panel.. gonna go with that instead of the pillar
Old Jul 25, 2012 | 07:59 AM
galantman03's Avatar
Originally Posted by todd6027
5v from pin 81 sensor power supply to toggle switch then from switch to adc input pin 42 .
for 8 usdm
change tephra mod options
enable alt maps master to adcof =1
Here is my problem, I'm using an evo 8 ecu on a 03 galant harness, and I don't have a pin 42 (evo side) on the conversion chart for my pin diagram. I would rather have the lights flasing instead of using a manual toggle, but IDK what button to wire it into to active the alt map switching.
Here is the pin conversion chart
http://www.thegalantcenter.org/showp...&postcount=253
Old Jul 25, 2012 | 09:18 AM
TSTARKZ123's Avatar
I had a similar question. Being as my chassis is an Evo 8 but my motor/harness/ECU is from a 9, I have the IC sprayer button and light on the dash but I don't think there is any pin out for it on the ECU. I'm assuming the only thing I can use is the TPS switching option, correct?
Old Jul 27, 2012 | 04:48 AM
pug206's Avatar
In the EDM IX have the ICS connector switch.
As easy as bypass the connector through.
Uploaded with ImageShack.us
Old May 26, 2014 | 07:06 AM
besk's Avatar
edit
weeeeeeeeee
Jun 27, 2016 04:01 PM
NitroWD
Jun 11, 2016 11:01 PM
Igaly1021
Jun 5, 2016 06:25 AM
clockworktoy
Dec 11, 2011 12:20 AM
06ravenmr
AEM EMS
Oct 29, 2009 01:57 PM
