Need Help!!!! Evo 5/6/6.5
Old Dec 12, 2011 | 03:32 PM
todd6027's Avatar
In Limits section "Ignition Retard Limit "
Old Dec 12, 2011 | 05:37 PM
wreckleford's Avatar
Cool, thanks guys. I didn't see that before.
Old May 13, 2014 | 02:39 AM
evoyrrah's Avatar
BUMP! im having a similar problem. but. whatever i set the ignition retard limit to IS the timing the ecu sets to on WOT. so if the limit is 5*....when on wot it will only be 5* from peak tq to redline .....im on ceddy mods also
Old May 13, 2014 | 04:58 AM
So you are saying if you set the map to 6 or 7 degrees you still get 5 degrees?
Old May 13, 2014 | 06:25 PM
evoyrrah's Avatar
Yes... On my timing map at peak tq is at 1* and ramps up to 11* to redline but wot logs show it's pegged to whatever the ignition retard limit table is set to
StarWolf
May 27, 2016 08:39 PM
StarWolf
Jan 11, 2016 07:20 AM
plastus
Aug 4, 2015 07:59 PM
nokia_aid
Apr 24, 2015 06:21 PM
SPD_FRK
Oct 13, 2011 03:28 PM
