Need Help!!!! Evo 5/6/6.5
Old Dec 8, 2011 | 04:53 PM
monkeyevo's Avatar
I'm using openport 2.0, I was trying to pull rom from evo 5 but not success. So I wonder that does evo 5 / 6 /6.5 have flash block ? or Do i need to put flash connector to pull or flash rom ? I was trying to find flash block But I could not find it.
One more thing, I'm using ECUflash 1.43+ and I have heard that Evo 5/6/6.5 only work with Ecuflash 1.41. So Now I dont know what to do in order to read and write rom to evo 5/6/6.5.
if Anyone has ideas, experiences or suggestion please let me know
Need help asap
Thank you so much guys
Old Dec 8, 2011 | 06:22 PM
monkeyevo's Avatar
anyone ?
Old Dec 8, 2011 | 09:36 PM
mistamidget's Avatar
you definitely need to connect the flash connector as well as the ODBII connector to read/flash the ECU.
I have a VI and the connector is tapped to the loom just above the ODBII connector.
I thought the V was readable so it must have the connector, but have never seen a V.
I have a 1997 GSR which didnt have the flash connector so had to use a TME ECU and add the wire and connector that I got from a loom at the car wreckers. so if the V is the same you could do that.
Old Dec 9, 2011 | 04:50 AM
Benja's Avatar
I've tuned/flashed several 5/6/TME, they all had the flash connector correctly hooked up, on the 5's though it was tucked away really tightly up above the loom that runs above the OBD plug.
Obviously if you can't find the flash plug, check that pin 79 on the ECU exists or not, if it doesn't there's your issue.
You need 1.43 to flash correctly with OP2.0.
Old Dec 10, 2011 | 06:20 AM
monkeyevo's Avatar
thank you so much guys ^^^^ So I just connect both flash connector and OBD II and I should be able to read and write Evo 5/6/6.5 ECU right ?
I will try to pull rom tomorrow and very appreciated your help guys!!
Old Dec 10, 2011 | 02:55 PM
foxbat's Avatar
An Evo 5 in LA! I'm curious what's her story?
Old Dec 10, 2011 | 06:45 PM
monkeyevo's Avatar
no i'm Thailand, its JDM evo 5 / 6
Old Dec 10, 2011 | 10:57 PM
Benja's Avatar
Yep, use 1.43, connect both items, select your vehicle type and away you go.
Old Dec 10, 2011 | 11:21 PM
sound77's Avatar
Evo 5/6 yes but 6.5 TME NO! the best way is to check your ECU by removing the ECU case. if its showing 7202 cpu then your OK, and if showing 7203 cpu then some other matters are to be done to read and write it
Old Dec 11, 2011 | 04:16 AM
todd6027's Avatar
not all tme had 7203 chip most ive come across had the normal 7202
Old Dec 12, 2011 | 11:37 AM
wreckleford's Avatar
Since we are on the subject of Evo 5-6.5, has anyone ever come across a problem with these in that once the Load goes above 260 the timing goes static to 5 degrees? I have this problem no matter what value I have in the 260 load column and no matter if I rescale the maps for higher load.
The car I have this with is using a Ceddy ROM.
Old Dec 12, 2011 | 11:56 AM
todd6027's Avatar
nope m8 weird one that ive done 300+ load on same rom with no probs what you got swtiched on/off in the peripherys / ign retard limit ,can send you a rom/ xml if needed
Old Dec 12, 2011 | 12:34 PM
donner's Avatar
In Ceddy rom (or actually ralliart rom) there is default +5 degrees (BTDC) limit for ignition advance, if you have not changed that ignition will not go lower than that no matter what you have on maps. This is first thing to check.
Old Dec 12, 2011 | 01:54 PM
So how do you change this? Periphery mod?
Old Dec 12, 2011 | 02:07 PM
donner's Avatar
No, there is parameter for that, something like "ignition max retard".
