XML for my ROM on diffrent laptop?
Old Dec 22, 2011 | 11:34 AM
grim~'s Avatar
Ok so later today i am going to hook up my car for the 1st to my laptop to ecuflash. now the car has been tuned with v7 but though a different tuner and different laptop. Do i need to get the xml from him for my rom or do i just download the corresponding one for my rom id?
Old Dec 22, 2011 | 12:42 PM
hearnoevo's Avatar
rom
download the rom from your car then save it to your laptop. Then you can make whatever changes you need to, save it as a different file name and flash it back to your car. That way you can flash back your previous tune if necessary.
Old Dec 22, 2011 | 01:53 PM
grim~'s Avatar
But would i be able to open it without the XML file?
Old Dec 22, 2011 | 04:50 PM
hearnoevo's Avatar
rom
you'll be able to open up the rom but the tephra options won't be visible without the xml.
Old Dec 22, 2011 | 04:56 PM
hearnoevo's Avatar
xml
follow the tephra v7 instructions and try copying the xml into your ecuflash directory first, then download your rom using ecuflash and see if the tephra options are there.
Old Dec 22, 2011 | 05:32 PM
grim~'s Avatar
ok i got the xml from the xml pack and got the rom open. i have a 2003 evo 8 5 speed yet in the rom id it says its a 2005 evo 6 speed. should that matter?
Old Dec 22, 2011 | 05:34 PM
codgi's Avatar
No it won't matter.
Old Dec 22, 2011 | 05:41 PM
grim~'s Avatar
ok cool thanks
Old Dec 24, 2011 | 12:21 AM
Prolifik's Avatar
im having weird problems ever since i started using 1.43 ecuflash to help with the ACD breakdowns....
Now, when ever i read the ROM, i can click and open all the tables like fuel and timing, but asoon as i click onto the tephra table to expand it, it just closes ECU flash instantly.....
no errors, just closes it.
Old Dec 24, 2011 | 03:16 AM
vd's Avatar
vd
You should check .xml file with any .xml-editor to see for incomplete definitions under that category. Newer Ecuflash versions force close once you address the table with imcomplete/erroneous definition. To rule out the problem completely you may need to check the final .xml as well as all the .xmls it inherits, other option is to get set of .xmls from someone who have them right at hand. Not me unfortunately, as I run 88580714.
TariqEvo
Dec 9, 2021 12:36 AM
3gevoclipse
Jan 31, 2016 10:07 AM
OttRalliart05
Lancer Engine Management / Tuning Forums
Dec 2, 2015 07:26 AM
Wanchai Panpron
Nov 30, 2015 06:46 AM
unihappytime
Mar 8, 2013 07:50 AM
