hows my tune?
Old Jan 22, 2012 | 07:38 PM
grim~'s Avatar
hows my tune?
ive been self tuning the car for the past week or so,got it from pegging out the wideband at 10afr at wot to this. the car seems smooth except for a little pop here and there. how is the timing curve,im not too sure if its ok or not,and how is the spool up to wot afrs? the is on 93 with about 26 psi on my setup in my sig. also any idea on why it knocked right there? this is a 3rd pull
Old Jan 22, 2012 | 08:25 PM
Vigman's Avatar
It spools late! How big is your turbo???
You should fix your knock (richer AFR @3300-3500RPM)
Also smooth your timing and try to be a bit richer in high revs.
Hope it helps.
Old Jan 22, 2012 | 08:44 PM
grim~'s Avatar
its a 6262 with .82 hotside, 11.0-11.3 isnt rich enough?
Old Jan 22, 2012 | 10:25 PM
hellcat's Avatar
That's about where you should be with pump gas tune if you aren't showing consistant knock anywhere. AFR wise anyhow. The stutter should be able to be tuned out with a lil timing change usually.
Old Jan 24, 2012 | 08:20 AM
boosted91t's Avatar
Post it up in Excel format, I just went crosseyed trying to look over it
Old Jan 24, 2012 | 08:28 AM
Raptord's Avatar
rename the .txt to .csv
Old Jan 24, 2012 | 02:29 PM
Raptord's Avatar
Took a look at your log, I would stay above 12.0 afr until you reach 200 load. From 200 load to peak boost tapper it down to ~11.5, and after that tapper it down to ~11-11.1 at 8k.
In the places that you're getting knock during spool I would try pulling 1 or 2 degrees and see if it helps.
Old Jan 24, 2012 | 06:32 PM
grim~'s Avatar
thanks!
Old Jan 25, 2012 | 03:15 PM
grim~'s Avatar
What about the timing curve? whats a good place to start at?
Old Jan 25, 2012 | 03:52 PM
Raptord's Avatar
What you have now seems reasonable. Like I said in my previous post, drop 1 or 2 degrees where you were getting knock and see if you can add some timing up top.
Ev0la
12
Nov 6, 2016 05:46 PM
Evo VIII 4o1
Jul 27, 2014 03:36 PM
EvoIXPilot
Apr 20, 2013 04:50 PM
ravenjam
Apr 12, 2012 09:06 PM
aronmatic
Apr 13, 2011 10:42 AM
