2012 gsr
just to clarify, i just copied 58010005.xml into the \openecu\ecuflash\rommetadata\mitsubishi\evo\ directory and open ECUFlash and open my ROM right?
that's what i did and it work, no message boxes or anything. this thing just knew my internal ID.
Yep, you should now see a good chunk of tables and "stuff". Most of the important stuff should be there, although there are still a few loose ends to attend to - idle speed tables, lean-spool, psi-based boost control, etc.
Rich
Rich
did you do the definitions for these? i would like to learn how to do these eventually or at least understand the general process better of how we went from a rom (hex i take it) to and xml.
Rich did the SST ones, yes. I did the GSR ones (by copying 95% of what Rich did for the SST
Learning is a bit tough. Go to Rich's disassembly thread and see if you can get that to work.
).Learning is a bit tough. Go to Rich's disassembly thread and see if you can get that to work.
yea, i've been talking back and forth with rich. it all makes sense now. i'm a programmer but i never work at machine language levels.
either way, you guys are amazing and a great benefit to all evo owners so i'm going to donate to both of you for your efforts, especially with hopes you will continue into the near future. i see i can paypal you at golden@goldenevo.com
same place for rich or donate to him seperately?
thanks!
mo
thanks!
mo
Gents , successfully with the help of my friend, we just reflashed my 2012. We did minor changes, mostly in the fuel trims, timing and boost. I will be most likely dynoing this car on its stock flash and then do the the full tune trim.
Being that I am not going to mod the car, other than a flash it will very interesting to see how much of a a power increase I will get. I am not looking at peak numbers but just and overall perfrormance increase ala a fq350 lol.
Btw thanks to those that did decoding I would mind working on ecus again. Which I did back on the srt world
Yep - if you enable it. The enablement-age items should be present and correct in Golden's definitions.
Rich
Rich
The_Austin_Deck
May 30, 2017 03:21 PM
