Post your tuning and monitoring setups!!!
Old Feb 15, 2012 | 09:32 AM
shubuduba's Avatar
As the title says, post up what you're using and how you like it!
Also Post pictures of your set up if you have 'em!!!
-Ecuflash-
-Cable-
Tactrix 1.3? 2.0?
-Logger-
Evoscan?
Mitsulogger?
-Wideband o2-
Zeitronix?
Aem uego?
Innovate?
Other?
-Boost controller-
Manual?
Electronic?
3-port?
-Mods-
Tephra?
Speed density?
Alt map switch?
Etc.
-Additional sensors-
Egt, oil psi, oil temp, water temp, etc.?
-What do you like about your set up?-
-What don't you like about your set up?-
-Future modifications/additions?-
Old Feb 15, 2012 | 10:14 AM
Raptord's Avatar
-Ecuflash-
1.43
-Cable-
1.3
-Logger-
Evoscan
-Wideband o2-
Zeitronix
-Boost controller-
Grimmspeed 3-port
-Mods-
Tephra w/ tps-based alt maps, ECU controlled boost
Had the full zeitronix kit with LCD, which includes MAP sensor, EGT and wideband when I bought the car. I've added oil temp but haven't added it to the LCD yet because it would have to replace boost (since I don't have the 2010+ LCD)
OMNI 3-bar MAP sensor
Everything was already installed when I bought the car except the oil temp sensor. Works great for tuning.
Can't have oil temp on my lcd while keeping boost.
Possibly upgrading to a 2010+ LCD screen to have oil temp and boost on at the same time
Old Feb 15, 2012 | 10:21 AM
evo8426's Avatar
-Ecuflash-
1.42
-Cable-
1.3
-Logger-
Evoscan 2.9
-Wideband o2-
Innovate LC-1
-Boost controller-
Grimmspeed 3 port
-Mods-
Tephra V7
JDM/Evo X 3 Bar MAP and AEM Digital Boost
It works
Nothing
Nothing
Old Feb 16, 2012 | 09:44 AM
vd's Avatar
vd
-Ecuflash-
1.43
-Cable-
2.0
-Logger-
Evoscan 2.9
-Wideband o2-
Zeitronix Zt-2
-Boost controller-
Grimmspeed 3-port
-Mods-
Tephra V7
OmniPower 4bar MAP-sensor, GM IAT
It works
Nothing
Nothing
Old Feb 16, 2012 | 06:53 PM
Sirnixalot's Avatar
Ecuflash 1.43
-Cable-
Tactrix 1.3
-Logger-
Evoscan 2.9
-Wideband o2-
Aem uego
-Boost controller-
None at the moment but i have a GM 3-port waiting for me to get the ambition to mess with it
-Mods-
Tephra V7
Apexi 60mm 2.5bar boost & oil temp
Summit Racing digital 52mm oil pressure and water temp
GM IAT sensor
It works
I need to make a mount for my netbook
Zeitronix ZT-2, ZR-2 with EGT and boost pressure sensor
Old Feb 16, 2012 | 08:21 PM
nonschlont's Avatar
-Ecuflash-
1.43
-Cable-
1.3 / 2.0
-Logger-
Evoscan 2.9
-Wideband o2-
Zeitronix Zt-2 LCD (WB only)
-Boost controller-
GM 3-port
-Mods-
had Tephra V7, Alt. Maps E-85 on my 9.
patiently waiting for V2 on my X.
None at the moment, but have a oil press. guage in garage.
It works
Nothing
Old Feb 22, 2012 | 07:21 AM
Stradag's Avatar
-Ecuflash-
1.43
-Cable-
Tactrix 1.3
-Logger-
Evoscan
-Wideband o2-
Zeitronix zt-2
-Boost controller-
Grimmspeed 3 port
-Mods-
Tephra V7
zeitronix egt map and wideband
Everything is contained to one unit, the zeitronix is defined in evoscan already so its plug and play. The zeitronix is also easy to use. I have used aem and lc1 and they arent as easily compatiable. Also I can get the replacement zeitronix oxygen sensors at my local parts store.
I also like using ecu controlled boost because when set up properly it will adjust for different outside temps so I dont have to mess with the boost controller to keep a solid boost level.
I dont liike the fact that I am lazy and havent ordered my oil temp sensor yet lmao
I wish someone would make a patch so I could use my zeitronix map sensor for speed density.
Tephra v7 Speed Density Conversion referencing fuel temp sensor for air temp.
I also have the zeitronix alarm I am wiring to disable my grimmspeed so boost will cut if afrs get too lean or egts get too high. The alarm also buzzes when it sees dangerous activities lol
Old Feb 22, 2012 | 07:55 AM
PeteyTurbo@KHC's Avatar
For OEM> http://www.etas.com/en/products/inca...e_products.php
Curious to know if anyone has used this software on here...
But usually I use evoscan and ecuflash for the evos lol
boomn29
Jul 8, 2019 05:09 PM
Raceghost
Aug 10, 2018 10:39 PM
Kracka
North Texas Evo Club (NTEC)
789
Sep 27, 2017 02:02 PM
Rom
Aug 7, 2017 04:22 AM
Dynotech Tuning
Sep 20, 2016 01:30 PM
