V7 - EGR delete: Periphery
Old Mar 17, 2012 | 03:30 PM
catman78's Avatar
Hi all,
For those who have removed EGR, which items in Periphery need to be disabled.
I'm removing EGR with my new build and want to make sure ROM is set up correctly.
I'm running 96531706.
thanks
Old Mar 17, 2012 | 03:45 PM
tscompusa's Avatar
assuming your xml is true with all options you would want to look under the table/column "global ignition settings" and zero out the EGR System Enable/Disable
it might also be under "other ecu options" EGR System Enable/Disable
my xml's are highly modified, so hopefully im giving somewhat accurate information.
for manual
go to periphery0 FAA = 0 out bit11
go to periphery2 FCA = 0 out bit9
Old Mar 18, 2012 | 03:16 AM
catman78's Avatar
Thanks Tom,
It was under Other ECU Options.
fostytou
359
Oct 23, 2025 09:54 AM
3gEclipseTurbo
18
Jul 20, 2012 10:00 AM
dimacoupe
Sep 1, 2011 05:31 AM
mifesto
Apr 19, 2011 08:27 AM
rolly1818
May 24, 2009 02:04 PM
