Questions with EVO 8 ECU in EVO 4
Old Mar 20, 2012 | 05:02 AM
Nic Money's Avatar
I have just installed an evo 8 ecu in my evo 4. I am wondering if anyone else has done this and if so I would like to get some information from you. Currently EvoScan is giving me the following DTC's
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0183 Fuel Temperature Sensor A Circuit High Input
P0443 Evaporative Emission Control System Purge Control Valve Circuit
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0340 Camshaft Position Sensor Circuit Malfunction
P0335 Crankshaft Position Sensor A Circuit Malfunction
P0118 Engine Coolant Temperature Circuit High Input
P0113 Intake Air Temperature Circuit High Input
P0102 Mass or Volume Air Flow Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
I have FIC 850cc injectors with a Walbro fuel pump and currently is running very rich.
The Internal ID I'm using is the stock evo 8 ROM ID with the Immobilizer disabled.
If anyone could please give me some information it would be very helpful.
Thanks
Old Mar 20, 2012 | 08:27 AM
wreckleford's Avatar
Reflash it with a 90550001 Rom or 9653XXXX Rom. You will still have to kill a few codes. The biggest issue will be the 2 wire front 02 sensor. The easiest thing to do is run it in open loop.
Old Mar 20, 2012 | 01:51 PM
stunt2's Avatar
Nic Money
if you want let me know your email and I'll send you the rom that I've set up for my evo4 as a base map. have no DTC's at all
Old Mar 20, 2012 | 03:51 PM
Nic Money's Avatar
Originally Posted by stunt2
Nic Money
That would be great. E-mail money_nic@yahoo.com Thanks.
Old Mar 20, 2012 | 09:52 PM
stunt2's Avatar
sent
Old Mar 20, 2012 | 11:27 PM
Nic Money's Avatar
That ROM looks like a RA but there are no maps do you have a good xml file that works semi-well that way I can tweek it as i go?
Old Mar 21, 2012 | 10:57 AM
stunt2's Avatar
thats 96530706 tephra v7 rom. sent you xml. as well
Old Mar 21, 2012 | 12:44 PM
TJung's Avatar
sent
Hey, could You sned me this rom too? Pleaaaase
tomaszjung@streetracing.pl
Old Mar 21, 2012 | 11:32 PM
stunt2's Avatar
will send later today, when I get home
Old Mar 22, 2012 | 12:20 AM
TJung's Avatar
Thanks !
fireroasted
Aug 31, 2013 09:52 AM
babaz7
Jul 18, 2012 09:19 AM
GBAILEY472
Jan 15, 2010 09:20 AM
projekt_shocker
14
Oct 22, 2008 06:15 PM
BadazzCR
Aug 23, 2008 07:40 AM
