P0456 code.
Old Jun 6, 2007 | 01:20 PM
projekt_shocker's Avatar
P0456 code.
Hey wassup
My car been running this code for a long time... and now I want to get rid of it.
this is what i got about this code...
Judgment Criteria
• Internal pressure of the fuel tank has changed greater than 1,177 − 1,373 Pa (0.177 − 0.199 psi) in 128 seconds after the tank and vapor line were closed.
• ECM monitors for this condition once during drive cycle.
TROUBLESHOOTING HINTS (The most likely causes for this code to be set are) :
• Loose fuel cap.
• Fuel cap relief pressure is incorrect.
• Malfunction of the evaporative emission canister seal.
• Malfunction of the fuel tank, purge line or vapor line seal.
• Malfunction of the evaporative emission ventilation solenoid.
All i wanted to know is where to locate the evaporative emission canister seal, purge line, and evaporative emission ventilation solenoid....
I did a walbro fuel pump install, but does this cause the problem?
Old Jun 6, 2007 | 01:21 PM
also wanted to add this too.. i know its not the fuel cap.. i checked and double checked it numerous of times.. and no luck with that.. so i know its one of the last 3 i have to check.
Old Jun 6, 2007 | 01:24 PM
Blue Evo 8's Avatar
Originally Posted by projekt_shocker
Hey wassup
Judgment Criteria
• Loose fuel cap.
I think the evap thing is in the engine bay behind the motor, passenger side....worse come to worse look for it in the factory serive manual.
Check the condition of the fuel lines, check for fuel leaks or cracks in the system,
check to see if the evap soleniod is working
I would suggest getting a screen name and logging on to www.obd-codes.com
and posting up your question. There are some knowledgeable ASE mecanics that frequent that board.
Old Jun 6, 2007 | 01:25 PM
where do i locate the evap solenoid?
Blue Evo 8's Avatar
I think it should plug somewhere into the evap canister?
Old Jun 6, 2007 | 01:27 PM
it sucks not having a evo service manual handy.. but i dont know where to locate those items so i can troubleshoot this. if there is anyone that can post a pdf or a pic of it that be nice.
Old Jun 6, 2007 | 01:35 PM
Blue Evo 8's Avatar
I'll see if I can get a link where you can download a free EVO service manual when i get home tonight...
meanwhile I dont know if you saw my previous post...
www.obd-codes.com
Old Jun 6, 2007 | 01:46 PM
mikesdad's Avatar
AFAIK the canister is tucked into the drivers rear quarter panel, just below the fuel door.
You can look up from the ground and see it, and all it's attached hosing, etc. right behind the rear tire.
Old Oct 17, 2007 | 01:22 PM
Evoryder's Avatar
I have this same code right after installing a walbro on my car....(installed walbro on many other evo's)
annoying code..
Old Apr 18, 2008 | 09:22 PM
evovin's Avatar
Bump for this topic....(I searched first) I had this code P0456 for the very 1st time couple days ago. I just cleared it ans since then it didn't throw a cell again.
Old Oct 9, 2008 | 05:59 PM
evoixbri's Avatar
bump for I got a new motor put in cause i threw a rod and now my car is coming up with PO456, Dealer did evap test and it was clear, and changed my gas cap and light still comes on. Any idea what or where it could be from? I think I hear a strange sound on the passenger side by the top of the left of the motor when facing the motor. maybe a hose leak? who knows. gotta bring it back next monday again. but any ideas?
Old Oct 10, 2008 | 09:30 AM
DanJ's Avatar
Anyone had any luck getting rid of this code?
My car is completely stock and I throw this code, I've retightened the fuel cap several times only to have the code pop-back on after a few hours of driving.
Old Oct 19, 2008 | 07:37 PM
DanJ's Avatar
Has anyone had any luck fixing this? I hate driving the car around with a CEL.
Old Oct 22, 2008 | 06:07 PM
itscypha's Avatar
not a evo and i have the code too. put new gas cap and redid vacuum lines so its definately solenoid or line around it. doubt its a fuel leak situation. hopefully someone figures it out so i can try the similar thing.
Old Oct 22, 2008 | 06:15 PM
evoixbri's Avatar
i had the same code for the longest, the dealer replaced my gas cap and it stayed on. The dealer found that my vacuum line for my intake had a crack in it. So i would advice to check all your vacuum lines for cracks. good luck ! my light is never on anymore.. thank god.
fostytou
359
Oct 23, 2025 09:54 AM
Nic Money
Mar 22, 2012 12:20 AM
GBAILEY472
Jan 15, 2010 09:20 AM
BadazzCR
Aug 23, 2008 07:40 AM
Kc2Buk
61
May 5, 2006 11:39 AM
