need help with ecuflash
Old Mar 22, 2012 | 04:55 AM
Harismr8's Avatar
hi....
I have two problems with ecu flash and my tuning stay freeze.
First the pop up window with vehicle type is empty when trying to log ecu, by ecuflash.
Second I download the ecu image with other laptop but when i open the image with ecu flash some values 'I think' are not correct. Take a look on rpm and load engine values.
RPM: 395, 461, 2559.., 1364.., 2559...,1406..., 105, 0, 39,78,117,156,195,234,273.
LOAD: 41,43,47,50,53,56,59,62,66,69,72,74,78,80,204...,1 09...,204...,112...
ecu id: 96260007
Old Mar 22, 2012 | 02:24 PM
HyperDisorder's Avatar
I suggest you start by replacing your 96260007.xml with the xml on this page:
http://ecurom.googlecode.com/svn/tru...o/96260007.xml
I just gave it a go, and the fuel and timing maps' axes look good now.
Old Mar 24, 2012 | 12:36 AM
Harismr8's Avatar
I replaced the file but the axes still be the same.
Any other suggestion?
Thanks
Old Mar 24, 2012 | 12:39 AM
That's strange. You mind posting up your rom? I'll double-check those axes.
Old Mar 24, 2012 | 12:45 AM
Harismr8's Avatar
evoviiimrsecond.hex
Old Mar 24, 2012 | 02:45 AM
burgers22's Avatar
Most likely you have put the new xml in the wrong directory, or the old xml exists somewhere else, change the file extension of the old xml to .txt
try out this xml just in case, but remember both points above.
File Type: zip
Old Mar 24, 2012 | 02:48 AM
Hmmm, that xml should have worked. I've attached an xml - just rename it from .txt to .xml and give it a go. It's the one I used.
Edit: I see a mistake in the xml - the "Wastgate Solenoid Activation RPM" address should be 1a68, not 1668.
Edit 2: Beaten to the punch haha!
File Type: txt
Old Mar 25, 2012 | 02:03 AM
Harismr8's Avatar
i replaced the xml files but there is no different but i change the addresses manual in the ecuflash but i am not sure if this is ok.
Thanks.
Old Mar 25, 2012 | 02:06 AM
burgers22's Avatar
What version of ECUFlash are you using? Earlier versions used different edians which meant maps were sometimes garbled
Old Mar 25, 2012 | 09:21 AM
Harismr8's Avatar
I am using
ECU FLASH v1.42.3252
Old Mar 26, 2012 | 12:12 PM
burgers22's Avatar
The xml you posted has some problems. Use the one I posted and you should be good to go. Make sure you delete all your old 9626007 xmls, even the ones in the metadata folder, as ECUflash will remembers the location of the old files.
