Fuel trims zero?
Old Sep 20, 2012 | 01:37 PM
  #31
fostytou's Avatar
EvoM Community Team
Originally Posted by wazzelby
Ok, so I saw in this thread that there is an issue with logging fuel trims. I'm having this problem and can't figure out why. I'm running the 88590715 ROM (US IX) and since switching it to Tephra v7 I can't log fuel trims. I've tried the obvious - re-install the rom, re-download the rom.. Nothing is working. If I load my stock tweaked rom fuel trims log just fine.
Anyone have any ideas??
You realize this is the Evo X section, right?
There is a thread in the CT9A section about the same thing. If you download a Phenem ROM I would stop there and start with a real Tephra ROM. If you disabled the rear O2 or did something else with O2/trims That is your next target.
Old Sep 20, 2012 | 01:53 PM
  #32
JohnBradley's Avatar
Have you played with the "Closed Loop Long Term Fuel control" or something to that effect? If it has been dropped below a certain Hz range to keep the LTFT from being applied in boost it could affect cruise if it was high enough. Between periphery and bad sensors that should be the only 2 other causes.
foxbat
Jun 13, 2016 01:43 PM
Toekneee!
Aug 24, 2015 07:01 PM
joshesh
Mar 7, 2015 12:37 PM
leecavturbo
Mar 4, 2011 07:03 AM
3gEclipseTurbo
Jan 28, 2010 01:41 PM
