tephra launch maps
Old May 18, 2014 | 07:54 PM
  #31
Ralliart004's Avatar
Veteran: Air Force
Originally Posted by 211ratsbud
Remember clutches are cheaper than transfer cases and transmissions.
That's the truth right there....
Old May 18, 2014 | 07:57 PM
  #32
detroit pistins's Avatar
Ya I primarily started building the launch map for the track, the treated pavement could be related, but I know my map isn't ready yet .... def need to spend some time on it before hitting the strip once again.
How are you able to build boost sooner?.... the only way I could think of is to start pulling timing much earlier than the limiter speed....sort of start at 2000 rpm and on.... Are we on the same page?
Old May 18, 2014 | 08:11 PM
  #33
211Ratsbud's Avatar
Same page but you need to build your map so that you won't run out of retard, cause if you do and you have any boost built the motor will instantly rev very hard. This takes a bit fuel tuning too but can help a big turbo get up quicker. Post a log or map trace. And your map if you want.
I've done some very bad things to my car using an entire map of -20 and holding the pedal wide open. Lots of boost to be had with out a limiter lol
Old May 18, 2014 | 08:17 PM
  #34
Will share the data once I get it dialed in for sure. Thanks for all the tips and info!
kstrizzom
Mar 10, 2017 02:42 AM
4b11slayer
Nov 17, 2016 11:30 AM
xBoostx
Oct 7, 2016 01:47 AM
Evo_Goodness
Aug 30, 2016 04:00 AM
