PTE 1200cc hard start!?
Old May 18, 2012 | 05:31 AM
audiofan's Avatar
I installed new PTE 1200cc injectors, used size and latency that were posted here in the forums, and it runs good.
But I have some trouble starting, it takes couple of second to start, and sometimes 2 o 3 turns on the key. There is too much fuel when cranking, I leave a round black stain on the wall, and have some smoke coming from time to time.
What parameter should I change in ecuflash to help start the car better?
Thanks
Old May 18, 2012 | 09:34 AM
boosted91t's Avatar
Does it start easier if you depress the throttle lightly?
What fuel?
Old May 18, 2012 | 10:46 AM
audiofan's Avatar
What fuel?
Yes! Throttle makes it easier
Pump only
Old May 18, 2012 | 10:57 AM
Sidnakit's Avatar
i have the same problem with my 880cc's on 91 oct. but my tune is not done and i think im going to change the injector seals and "o" rings
Old May 18, 2012 | 04:16 PM
audiofan's Avatar
My tune is not done, but scaling, size and latency seems ok when driving, WOT, etc.
I used the brand new seals and o rings that came with the injectors, and there is no fuel leak.
Old May 18, 2012 | 04:27 PM
brakeboost980's Avatar
Its not the scaling ,it's the injectors themselves.Next time get fic..
Old May 18, 2012 | 04:42 PM
slipperychicken's Avatar
^ Um no, nothing wrong with the injectors... OP it depends on the ROM. You would adjust cranking primer initial pulse or initial cranking ipw v coolant temp.
Old May 18, 2012 | 04:49 PM
marcoEVO9's Avatar
when i had my PTE i had the same issues. Does it start easier on cold mornings?
Old May 18, 2012 | 06:39 PM
merlin.oz's Avatar
Find your cranking tables and multiply each value by 0.65.
That will get you close (or closer than you are at present anyway) and may be all it requires as a gas/E85 compromise.
Old May 18, 2012 | 09:35 PM
audiofan's Avatar
ROM: 96530706
Thanks! I will try this and post results.
Is it the Cranking Primer Initial Pulse inside the main map fuel settings?
or Inside Global Fuel settings - startup there are 3: Initial Cranking IPW vs coolant temp, cranking IPW compensation vs time and IPW comp starting?
Old May 18, 2012 | 10:39 PM
Anarchy99's Avatar
I don't believe in loading canned scaling and latency. I believe every individual car needs the scaling and latency customized for the engine and mods, octane and altitude as a whole picture. go get it pro tuned
silentkiller
Jun 8, 2013 02:00 AM
dmotors
Apr 11, 2010 07:57 AM
mpfcc
Sep 17, 2009 11:27 PM
evovin
Jul 11, 2008 05:27 PM
juice_evo_VII
AEM EMS
Apr 30, 2008 04:51 PM
