ecuflash load rescale map..correct or not?
i just finished rescaling my load on my ecuflash ....at first they were stock from 0 to 260..now there from 0 to 300,i just wana post my maps up and let you guys see if there correct and i should flash it in my car.
i have posted both maps,plz take a look and see if i made any mistakes and need to change anything.
As you scan across the load columns from left to right, especially for your low oct ign map, there should be no more than 5* difference for a change of 20 load. For example you change from 26* to 16* at 3500 rpm when moving from 80 to 100 load. This is right in the spool transition to boost and is likely to give you some knock (=bad for your engine). Try smoothing the transition more to something like this.
You can also use the autosmoothing spreadsheet at:http://code.google.com/p/ecurom/sour...eadsheets?r=65to make this easier.
Ludikraut
Jan 27, 2020 05:42 AM
