Disable P0300 on the Evo 10
ok, I'd have to dig deeper to separate out the P0300 from the P030X codes. Not sure when I'll be able to get to that.
So yea I hear ya on that, but still it could help spot something not in WOT that makes you check a bad sparkplug early or something.
I found these the day that MrFred posted... I guess should have posted then.
For 5557, 8 and 9:
<table name="DTC P0300 Disable/Enable (0/1)" category="Misc" address="503b5" type="1D" level="1" scaling="uint8"/>
For 5557, 8 and 9:
Aaron
Just to be clear, it only disables P300, P0301, P0302, P0303, P0304. I'm still puzzled why you guys are worried about the P030X codes. A consistent misfire is easy to detect by seat of the pants. Heck, even a random misfire can typically be detected in a datalog. An example of something I wouldn't disable would be a crank sensor or cam sensor code.
Mine did. I wouldn't have know there was a problem either had it not been for the code. The car seemed to be running fine, threw the code so I pulled the spark plugs and found one of them to be damaged.
Honestly that is an oddity. They have thrown them for clutches, cams, valvesprings, dogs barking, etc. but I have never seen the P0300 for a misfire. In the 1G and 2G it will do it on a 6 bolt swap when you switch the cam sensors. Like Mychailo said, you can feel the hickup from a misfire, see it in a log or dynosheet (100whp drop sometimes), and never actually throw the code.
