AFR cant goes below 11??? Why???
Old Jun 28, 2012 | 01:36 PM
jameswwt's Avatar
Originally Posted by Boosted Tuning
A couple things.
If you scaling in the ECU is higher then what the injectors are rated for, its wrong.
If you have an EVO 8 or lower, then yes, you need to reset the battery and the trims between each injector scaling attempt.
And the VTA BOV is NOT helping you. Go back to a recirculated setup.
Thanks Boosted Tuning, will try few more attempt for the scaling as now matter what scaling values i throw in, its the 943cc is the closes to 14.7AFR ecu AFR.
Will a re-circulate bov helps on my stalling problem due to sudden rich while throttle lift off?
Old Jun 28, 2012 | 02:07 PM
dolphin888's Avatar
It's one of very first things to check, when you have stalling problems.
Old Sep 10, 2012 | 08:38 AM
t2000cz's Avatar
Is it ok when I have to enter about 0.5-1.2 unit lower values into my high octane fuel map to get correct AFR output from my LC-1 when running WAT from 3500 till redline?
The car is Evo 8 260 with standard injectors, japspeed downpipe and boost about 1.5bar(smaller pillow bar). I use the 96530006 ROM with standard MAF and injector values.
I will install the walbro fuel pump this week, to be sure that the pump is not running out of duty.
Thanks for any ideas.
V.
Old Sep 10, 2012 | 10:06 AM
Boosted Tuning's Avatar
V.
Yes. The fuel maps are just numbers. It doesnt matter what the fuel maps AFR says. It only matters if the right AFR is being recorded by the wideband.
Old Sep 10, 2012 | 10:53 AM
t2000cz's Avatar
Thanks
def1
Feb 2, 2017 10:34 AM
EvoIXPilot
Apr 12, 2013 09:56 AM
BhpTuner
Sep 18, 2010 07:16 AM
Oettinger
Feb 24, 2008 04:03 AM
althemean
31
May 2, 2006 12:20 PM
