Big map translator question...
Old Jul 2, 2012 | 01:22 AM
babaz7's Avatar
hi, i have the v7 up and running after about a week of trying...
now i want to know how to convert my previous map to the new v7..
i have downloaded the big map translator but was confused a little, do i just copy my fuel map and ignition map to the big map translator 350 load cell map and paste?
the rest it will do automatically or i need to do it manually?
Old Jul 3, 2012 | 01:44 AM
babaz7's Avatar
i just copied my hi octane mp and pasted in the map translator and this is the map i got, does this look ok and should i flash it?
and another thing, just below the map translator it says copy the < 1000000 in the last coloum/row what does it mean?
Old Jul 3, 2012 | 02:01 AM
babaz7's Avatar
and when i copy/paste my fuel map in the map translator it gives me funny numbers, till 240 load its fuel then its jus ignition maps...
Old Jul 3, 2012 | 02:28 AM
07EvoIX's Avatar
for the timing map, just simply copy and paste it and you should be done. for the fuel, copy and paste the map and then move the 2 grey values to the next row/column after the last cells of the small map.
cheers
Old Jul 3, 2012 | 04:43 AM
babaz7's Avatar
cheers
like this....is this right?
Old Jul 3, 2012 | 03:31 PM
07EvoIX's Avatar
it should look like this
Old Jul 3, 2012 | 10:33 PM
babaz7's Avatar
ok i tried everything but it didnt look like that...now im posting a pic of the 300 load cell map, tell me where should the grey value of 100000 go, theres one in the top right corner and one in the left bottom, tell me where both should go...thanks
Old Jul 3, 2012 | 10:41 PM
07EvoIX's Avatar
ill try and word the instructions for you, hopefully i can word it in an understandable way...
1) Copy your RPM column from ECUFlash to the RPM column of the spreadsheet for small map
2) Copy the RPM 1000000 value to the next cell under your last RPM value
3) Copy your Load row from ECUFlash to the Load row of the spreadsheet for small map
4) Copy the Load 1000000 value to the next cell next to your last Load value
5) Clear all the cell contents from their values (the values where you will be pasting your map)
6) Copy and paste your fuel map to the spreadsheet
7) Big Map should be done
hope that clear.
cheers
Old Jul 3, 2012 | 11:23 PM
babaz7's Avatar
ok i did it now just tell me does this look right?
i know the new fuel map looks right but im not sure about the 4x100000 in the rpm colum, should i leave it like that or change it?
Attached Thumbnails Big map translator question...-new-map.jpg   Big map translator question...-kjkjiuiuiyiih.jpg
Old Jul 3, 2012 | 11:28 PM
babaz7's Avatar
hope that clear.
cheers
and thanks for helpind and answering my question..i know im bothering you,but without your help, i cannot do it...
Old Jul 4, 2012 | 01:25 AM
07EvoIX's Avatar
yeah that looks right
happy to help
cheers
Old Mar 5, 2017 | 07:02 AM
kstrizzom's Avatar
i did this with the timing map with no issues but when i try my fuel map the values are rounded to whole numbers
also how am i to transfer the rest of my maps to the tephra
Old May 27, 2021 | 11:35 PM
Lancer_Evo_8's Avatar
I translated my small Map to the Big Map Tephra V7 incl. compare vom small to big. Now when i go WOT the KnockSum light ist flashing. But with the small Map the car was running absolutly perfect.
Is there somebody how can check?
domyz
Jul 27, 2022 11:54 AM
4b11slayer
Nov 17, 2016 11:30 AM
Ta/Fc1383
Apr 28, 2016 06:34 AM
jmrussell89
Mar 17, 2016 06:34 PM
