Need help urgent!!
Old Jul 9, 2012 | 11:50 AM
def1's Avatar
Need help urgent!!
I flashed my car yesterday with an updated map, it was the same one I was using just adjusted the injector settings. The car would not hold idle at all it would just die as soon as I let off the gas pedal.
I tried a billion different things and decided to throw on my original stock map which is the 94170008 map and things have gotten even worse. Now the car wont start at all. I decided to log the attempt at starting the car with evoscan and you can read the values are all weird.
I've uploaded the excel file showing the evoscan data.
Please help me. What could have happened? Did my ecu go corrupt?
Old Jul 9, 2012 | 02:05 PM
stunt2's Avatar
immobiliser code ?
Old Jul 9, 2012 | 02:32 PM
def1's Avatar
No immobilizer code is good. I flashed to another map and the car starts now but it still wont hold idle at all. Im not sure why evoscan was reading those weird values tho.
Perhaps its a coincidence it happened after the flash because the maps were idling perfect before.
I know its not the fuel pump because i can keep the car on as long as i pump the gas after turning it on. Im starting to think it might be the idle control valve since none of the maps are working at idle anymore but work well after.
Any other ideas?
I should also mention when the car starts cold, it will idle fine, but the second i drive and come to a stop it will die and won't idle at all afterwards
Old Jul 9, 2012 | 09:49 PM
stunt2's Avatar
try to park you idle stepper with evoscan and adjust idle via biss scrw. you know the procedure I hope. might help
Old Jul 10, 2012 | 04:06 PM
VIIIdriver's Avatar
U still having the same issue? if you are send me your current rom and i'll take a look at it to see if there's anything weird on it.Pm me for email.
Old Jul 11, 2012 | 08:25 AM
def1's Avatar
Yea still having the same problem. I think I'll take up your offer and PM you VIIIdriver, I really want to make sure its not an ecu problem before I go buy a new ICS valve
Old Jul 11, 2012 | 01:49 PM
VIIIdriver's Avatar
I'll be waiting my friend!
Wmu240
Sep 8, 2015 06:21 PM
killerpenguin21
Apr 27, 2011 02:52 PM
korndogg
Mar 24, 2010 01:57 PM
mrx79
May 31, 2008 06:25 AM
tkklemann
Jun 8, 2007 03:38 PM
