open loop question...help needed.
Old Jul 11, 2012 | 09:03 AM
Raptord's Avatar
oxygen sensor will be the o2 sensor's voltage, varying between 0 and 1. STFT is the short term correction the ECU is applying to reach 14.7 afr at that moment based on o2 sensor feedback. Values range from -25 to +25.
Old Jul 11, 2012 | 09:20 AM
babaz7's Avatar
i cant find the o2 sensor voltage can you tell me which one is it?
Old Jul 11, 2012 | 09:34 AM
Raptord's Avatar
oxygen sensor (1)
Old Jul 11, 2012 | 10:55 AM
Spec-Ops1's Avatar
Also are you positive you do not have an exhaust leak? An exhasut leak before the wideband O2 sensor would genereate a "lean" condition FYI...
Old Jul 11, 2012 | 02:05 PM
akeric's Avatar
true, could be getting enough flow at cruise and full throttle runs to read properly and only really leaking bad at idle. OP you could varify this by looking at your fuel trims in evoscan. If you short term fuel trim is pegged +12% or 25% (can't remember where it maxes) at 17afr at idle then your probably idling in the right afr range and just getting a bad wideband reading.
Old Jul 11, 2012 | 03:36 PM
Raptord's Avatar
Max/min STFT is +/- 25.
Max/min LTFT is +/- 12.5
Old Jul 11, 2012 | 11:04 PM
babaz7's Avatar
i took the datalog at idle but it fails to upload over here....any tips on how to upload?
its a 2mb file.
Old Jul 11, 2012 | 11:06 PM
babaz7's Avatar
i'll re-tighten the nuts and see what happens...
Old Jul 11, 2012 | 11:17 PM
akeric's Avatar
its a 2mb file.
open the log in excel or openoffice calc and take a screen shot of it and post the pic. Doesn't need to be a huge log if it's just idle.
Old Jul 12, 2012 | 03:32 AM
babaz7's Avatar
ok here are the pics of the data log..
tell me what do you see, do i need to replace the front o2 sensor?
Attached Thumbnails open loop question...help needed.-part-1.jpg   open loop question...help needed.-part-2.jpg   open loop question...help needed.-part-3.jpg   open loop question...help needed.-part-4.jpg   open loop question...help needed.-part-5.png
Old Jul 12, 2012 | 04:30 AM
Spec-Ops1's Avatar
You will have to log fuel trims and post a file where we can see what is going on... that screenshot did not show fuel trims...
Old Jul 12, 2012 | 05:04 AM
babaz7's Avatar
ok i'll data log again and report back.
Old Jul 12, 2012 | 05:49 AM
Raptord's Avatar
Put it in a .zip archive, then you'll be able to upload it.
Old Jul 12, 2012 | 06:18 AM
ReaperX's Avatar
To me, it looks like your front o2 is on it's way out. Your timing at idle hits a low of 6* and a high of 18* with your o2 voltage going from .15xx to .8xxx. Does it have a rougher idle than usual, or sound like it lopes a little more than usual with the cams?
My car doesn't have cams but, if you heard it at idle and didn't know the car, you'd think it did have cams. I'll be replacing my o2 this weekend, I'll post a log of my idle so you can compare tonight.
Old Jul 12, 2012 | 06:29 AM
Raptord's Avatar
It's normal for the sensor's reading to vary from low, to high, back to low, etc. The key is that if you plot o2 voltage vs time, it should look like a fairly regular variance, not one that is seemingly random.
Try logging JUST o2 sensor reading (to get the best sample rate). Then create a line chart in excel of o2 sensor voltage relative to time. Post that up.
