Cams + Im : timing +afr
Old Aug 15, 2012 | 03:00 PM
211Ratsbud's Avatar
ok ive been smoothing in a bunch of cruise light throttle timing. Ill post a log of this one later, knocked when i first flashed it but after a while stopped knocking..
File Type: hex
Old Aug 16, 2012 | 03:36 AM
211Ratsbud's Avatar
still knocks coming across those same cells. Ive made it a tad richer too
File Type: hex
Old Aug 16, 2012 | 01:36 PM
charlie.tunah's Avatar
I dont know why, but I cant ever open .zip files from here...
OT...but I want to thank boosted91t. The >4500 <90 load portion of your map may have finally fixed my shift knock issues.
Old Aug 16, 2012 | 02:01 PM
todd6027's Avatar
@211ratsbud what rom id ??
Old Aug 16, 2012 | 02:09 PM
211Ratsbud's Avatar
88592715 speed density 2.0
Old Aug 16, 2012 | 04:53 PM
211Ratsbud's Avatar
Still a knock around 90 to 100 load. Definitely have to make a set of set cans
Old Aug 17, 2012 | 12:01 PM
211Ratsbud's Avatar
well heres one thing.. i know my knock limits are set to stock like 60 load at all these places but I want to make sure its good to go. and gain further understanding of my motor.
Ps this was on v14 rom if u need I can upload it here
Old Aug 17, 2012 | 01:37 PM
211Ratsbud's Avatar
http://www.lukekailburn.com/detcan.html
Here's how I plan to do homemade det can
And I'm gonna do plugs tomorrow
Old Aug 17, 2012 | 02:22 PM
laramie_05MR's Avatar
I had phantom knock with my S2s between 2400 and 3k around 100 load.
Old Aug 17, 2012 | 05:52 PM
foxbat's Avatar
S2s + springs/retainers, good formula for phantom. If you reduce timing & knock counts persist then it must be phantom. Just de-tune knock control, it works like a charm.
Is your turbo still stock? I really question the choice of S2s for an auto-cross car!
Old Aug 17, 2012 | 06:14 PM
211Ratsbud's Avatar
Fp 71 hta, I'm at 25 psi by 3500 it's not that bad really. I do miss the has cams though a little more responsive down low. However I've gained midrange out the wazoo.
Laramie elaborate on the conditions of your problem if you can
Old Aug 17, 2012 | 08:56 PM
foxbat's Avatar
S2s are made for much bigger turbos such as a GT35! Based on my extensive experience in autocross racing, a smaller degree cams would work better with smaller turbos & for autocross. I recommend 264 degrees cams, (HKS are the best for that size). Just like Laramie, I had an issue with an S2 equipped Evo, but knock was between 4000-6000rpm 18-22psi with really high counts & I had to adjust knock control.
One possible mechanical fix is to replace aftermarket retainers & possibly springs with stock parts (if cams size allows it).
Old Aug 18, 2012 | 06:22 AM
211Ratsbud's Avatar
Yea pulling timing doesn't seem to help. Once I make the det can I need to figure out how to adjust the knock filter properly
This is why I wanted the anti lag so bad. I thought I would be able to get away with a more aggressive set up and have stock like or better response
Old Aug 18, 2012 | 10:28 AM
evo8426's Avatar
I would never recommend anything less than S2 or Kelford 272. They do not cause any lag on a stock turbo. Just like I would never recommend an HKS cam since there are much better options available.
Old Aug 18, 2012 | 01:29 PM
foxbat's Avatar
You have misread my comment, my advice applies only to 'autocross' in which 90% are spent in low-mid speeds.
HKS are the best in terms of low-end response, check the AMS cam comparison post.
Unlike you mentioned, S2s will even cause more lag unless used with a 'larger' than stock turbo: http://www.power-division.com/produc...cat=306&page=1
