drop boost on high knock
Old Aug 15, 2012 | 04:16 AM
charlie.tunah's Avatar
Do any of you use this feature with V7? Ive had it setup for a while but just wondering if its causing more harm than good. Knock typically goes away, but I know the transition from full boost to wastgate pressure isnt typically a smooth transition and can cause issues in itself.
If you use it, does it work well, and are you dropping to wastegate pressure or just a couple psi lower? If you dont use it, why?
Old Aug 15, 2012 | 04:36 AM
211Ratsbud's Avatar
Is there a table for how much to drop ? I only see duration
Old Aug 15, 2012 | 08:52 AM
I dont have my laptop in front of me, but there is a table that says somethign along the lines of "WGDC limit during fault". I have mine set to 0 at the moment.
Old Aug 15, 2012 | 09:01 AM
Raptord's Avatar
I think it just sets WGDC to 0, there's no table to control it AFAIK. "WGDC limit during fault" is also in the stock rom so it's not a v7-only table.
Old Aug 15, 2012 | 09:07 AM
211Ratsbud's Avatar
That's what I was thinking.
Still curious to see
Old Aug 15, 2012 | 10:26 AM
ahh. I see. Raptord, do you use this feature?
Old Aug 15, 2012 | 03:02 PM
ButcherDSM's Avatar
i use this, WGDC set to 0 on "High knock boost drop and knock CEL flash time"
it's working very well
Old Aug 15, 2012 | 08:21 PM
Raptord's Avatar
No I don't at this time.
Old Aug 16, 2012 | 07:59 AM
I dropped the timer to 1000ms. We will see if it helps. Im fighting shift knock, and just wondering whether this feature is actually making it worse as opposed to just lowering timing until the knock goes away.
Old Aug 16, 2012 | 08:52 AM
Anarchy99's Avatar
This is correct
senate6268
Lancer Engine Management / Tuning Forums
91
Dec 26, 2022 12:20 AM
Mellon Racing
Feb 17, 2016 01:22 PM
blk-majik
23
Aug 16, 2012 04:20 PM
AlwaysinBoost
Mar 17, 2011 06:51 PM
Slo_crx1
Jul 20, 2008 05:46 PM
