View Poll Results: Which version of Speed Density are you running?
3D Speed Density
40.00%
2D Speed Density
60.00%
Voters: 20. You may not vote on this poll
Which version of SD are you using? ...And Why?
Old Aug 31, 2012 | 05:47 AM
Douglas_Hammon's Avatar
Just curious to see how many people are running 3D SD vs. 2D SD, and why you chose the one you did.
Old Aug 31, 2012 | 06:24 AM
evo8426's Avatar
3d because it is the most current
Old Aug 31, 2012 | 08:25 AM
211Ratsbud's Avatar
3d.. Easier for me to comprehend
Old Aug 31, 2012 | 10:02 AM
todd6027's Avatar
2d cos its the only one available for my rom
Old Aug 31, 2012 | 11:14 AM
dolphin888's Avatar
2D. I am more familiar with it through years.
Old Sep 2, 2012 | 02:48 AM
charlie.tunah's Avatar
3d cause I like spending all year getting the tune sorted out.
Old Sep 2, 2012 | 03:31 AM
211Ratsbud's Avatar
aint that the damned truth!
Old Sep 2, 2012 | 07:23 AM
benderrodriguez's Avatar
3D for Fuel Economy and various driving conditions
Old Sep 2, 2012 | 08:58 AM
Dynotech Tuning's Avatar
2D for quick simplicity but 3D can mirror MAF much better if the tuner is given the time to mirror both.
-Jamie
Old Sep 2, 2012 | 09:00 AM
JohnBradley's Avatar
2D for almost all situations. 3D if its one of 3 cars in our stable.
Old Sep 3, 2012 | 12:27 AM
And's Avatar
And
3D as found it gives a nice finish to the tables, takes longer to sort but give you the fine tuning
Andy
Old Sep 3, 2012 | 12:41 AM
tscompusa's Avatar
2d and the car drives like this:
Old Sep 3, 2012 | 12:42 AM
tscompusa's Avatar
you dont need 3d to get fuel economy. my buddy Steve i tuned with a evo 9 gets 300Miles to a tank on e85.. it doesn't get much better then that.. and that is off o2 feedback just timing added to cruise. nothing to do with sd code.
my car with city driving recently managed 220 miles. with occasional WOT as i was trying to wear in my new transmission.
the important thing to know when using SD is to take advantage of not having to bottleneck the intake .. get a nice big intake with a big filter
and take advantage of the ability to allow the turbo to breath better. thats where the power comes from. i feel the car is much happier on sd then maf just by the way it responds differently.
Old Sep 3, 2012 | 12:46 PM
If you have a competent local dyno shop with a load bearing dyno that can help you load the dyno at specific RPM points, you can log an Evo on MAF with a map sensor and build a 3D VE table in about an hour. If you won't/can't start with a MAF tune first, its gonna take you a great deal longer to get it 'just right'.
Fuel economy isn't really any different between MAF,2D and 3D SD if tuned properly. The major difference is how smooth the transitions will be as engine load varies on 2D vs MAF or 3D.
-Jamie
Old Sep 3, 2012 | 05:00 PM
For my setup I run Open Loop 100% of the time. Without 3D I would go rich under certain condition at a specific manifold pressure, while lean under different conditions at the same pressure. This is where i get the fuel economy benefit.
