Idle Stability map?
Old Sep 18, 2012 | 03:02 AM
RS200Z's Avatar
Originally Posted by tephra
err im not 100%
im pretty sure it increases timing when its under target...
Thanks, I reckon in this case it's Target RPM minus Current RPM since positive RPM difference will add timing according to the table.
Old Sep 18, 2012 | 10:13 AM
JohnBradley's Avatar
Can I get a 53040010 ROM? I cant seem to find one to examine this. Addresses definitely dont line up for the US stuff.
Aaron
Old Sep 18, 2012 | 03:46 PM
tephra's Avatar
for 55590007 - sorry the only rom i had:
Code:
<scaling name="Idle RPM Offset" units="RPM diff" toexpr="(x-32768)*1000/256" frexpr="(x*256/1000)+32768" format="%.2f" min="0" max="100" inc="0.5" storagetype="uint16" endian="big"/>
<table name="Idle Timing Compensation 1" category="Idle" address="5fc46" type="2D" swapxy="false" scaling="IgnitionCompensation">
	<table name="RPM" address="62900" type="Y Axis" elements="29" scaling="Idle RPM Offset"/>
</table>
<table name="Idle Timing Compensation 2" category="Idle" address="5f66e" type="2D" swapxy="false" scaling="IgnitionCompensation">
</table>
Old Sep 18, 2012 | 04:06 PM
richardjh's Avatar
I'll do a big pile o' ROM defs tonight, okay? They will be up on golden's site.
Rich
Awesome, thank you.
Aaron
Old Sep 18, 2012 | 04:25 PM
One thing I noticed real quick is that the target error looks like what I posted more or less but with the other axis doesnt appear correct? I am getting numbers in the 2000 range?
Old Sep 18, 2012 | 04:43 PM
tephra's Avatar
what other axis?
its only 2d
Old Sep 18, 2012 | 05:01 PM
I have the error column which goes from -199 to +199 but the other column (I guess axis isnt the right word) is not using numbers as I know them. Is it supposed to be timing in that column? It said RPM or something and then when I labelled it I got a blank in the xml. I may have added the wrong scaling.
Old Sep 18, 2012 | 08:19 PM
tephra's Avatar
the right column is meant to just be the timing compensations
ie starts at -8 goes to 8, 0 in the middle..
i would say check your definition for "IgnitionCompensation"
Old Sep 19, 2012 | 06:46 AM
richardjh's Avatar
Hey tephra,
Those two pairs of tables you defined... for 55590006 and 53040010...
They aren't the same. In each ROM, there is a pair of tables referenced... then 20 lines later, a second pair of tables is referenced.
The def for 5304 is for the "top pair". The def for 5559 is for the "bottom pair".
Can you please clarify? Anything you know would help.
Cheers,
Rich
Old Sep 19, 2012 | 08:23 AM
E-SPEC INDUSTRIES's Avatar
Seems like there should be a similar table floating around for the dbw configuration as well.
Old Sep 19, 2012 | 11:01 AM
K, thanks But I figured out I dont have the scaling called IgnitionCompensation.
Old Sep 19, 2012 | 12:00 PM
NM, I found it with a quick google. So this is 2D where the STI adds an axis for MAP but this should be able to do it I think. I also figured out what the issue was, the IGT#1 had weird values, the IGT#2 matches your description.
I guess the next thing I would be curious about is if we can log where it is on this, though using some common sense I guess if the idle isnt what its set to then we know it needs bumped up.
aaron
Old Sep 19, 2012 | 04:21 PM
tephra's Avatar
Originally Posted by richardjh
Hey tephra,
Cheers,
Rich
Hrmm I missed that before, serves me right for doing it quickly
I've updated my original post (https://www.evolutionm.net/forums/10405980-post12.html) with all 4...
Old Sep 19, 2012 | 04:34 PM
richardjh's Avatar
Cool, I'll tweak the XML defs to reflect the four of 'em, and flesh this lot out for other ROMs.
Rich
