rescaling sub 100 load area ?
Old Sep 17, 2012 | 01:15 AM
stunt2's Avatar
Exclamation rescaling sub 100 load area ?
so guys, need more and detailed resolution in mid and top of my map and want to rescale it under 100 load area. my question is can I completely remove 10-20 loads ? in what circumstances are they in play ? as I don't want to sacrifice idling or off boost driveability
instead of 10-20-30-40-50-60-70-80-90-100 thinking about some options:
10-30-50-70-90-100
20-40-60-80-90-100
30-40-60-80-90-100
40-60-70-80-90-100
which one to go ?
Old Sep 17, 2012 | 06:11 AM
Boosted Tuning's Avatar
If you using a non V7 ROM, you will need to fix the other timing maps (EGR, low coolant trim).
Old Sep 17, 2012 | 07:18 AM
211Ratsbud's Avatar
I use the last scaling
Old Sep 17, 2012 | 08:29 AM
stunt2's Avatar
Boosted Tuning I use v7 rom
Old Sep 17, 2012 | 02:23 PM
stunt2's Avatar
anyone else ?
Old Sep 17, 2012 | 02:43 PM
todd6027's Avatar
option 1
Old Sep 17, 2012 | 04:05 PM
stunt2's Avatar
todd, bit detailed, why 1 ?
Old Sep 17, 2012 | 04:15 PM
211Ratsbud's Avatar
I see 405060 load during cruise so I actually use the lowest load on my table because thats the lowest load Ill be driving at. I see lower loads on overrun, but the ECU just interpolates below your lowest value and youre good to go.
40 load in my set up is mostly overrun, but i leave it there because light throttle down hill can hop this low.
Old Sep 17, 2012 | 04:39 PM
ExViTermini's Avatar
What about idle?
Old Sep 17, 2012 | 05:18 PM
211Ratsbud's Avatar
It just interpolates
Old Sep 17, 2012 | 06:44 PM
07EvoIX's Avatar
what load are you hitting at idle and what load you averaging at cruise? if you idle at 23 for example and cruise between 40-60, then i would set it to
20 40 50 60 90 100
also it depends on how your map looks, you dont want to over sacrifice tip-in and part throttle acceleration.
If you r40-60 map points are all exactly the same, then you could do
20 40 60 80 90 100
the options are endless and all depends on your setup/tune.
also, how many map points do you want to add? where exactly so you want to add them? have you considered getting rid of 110 and going from 100 120 instead?
cheers
Old Sep 17, 2012 | 09:49 PM
stunt2's Avatar
I idle at 40 load. as about cruise, do not remember exactly tbh
and I need resolution between 100-200 incremented by 10 instead of 20 and also want to expand map past 350 load a bit
Old Sep 17, 2012 | 10:16 PM
07EvoIX's Avatar
for my ROM, my 10-40 maps are identical except for fuel >6000 RPM @ 40 load. the probability at being over 6000 RPm & 40 load is very low except under decel.
So, if you are similar then you could start at 40 load as everything under is the same so the ECU would interpolate accoridngly where needed. there is 3 map points you could gain.
again for my ROM, my 50 & 60 loads are identical except for 1 cell @ 6000 RPM. so again i could get rid of 50 load point.
you really just need to check your ROM and determine what can go and what needs to stay.
so for MY ROM, if i was in your situation i would have
40 60 70 80 90 100
cheers
Old Sep 18, 2012 | 03:03 AM
todd6027's Avatar
it idles better if you leave 10 in also behaves better on deceleration
Ludikraut
Jan 27, 2020 05:42 AM
stunt2
May 25, 2012 01:46 PM
whiterexman
11
Oct 27, 2004 01:07 PM
MalibuJack
29
Sep 3, 2004 08:20 PM
BigBoogieman
Apr 11, 2004 11:47 PM
