Mapping Evo 6.5 TME
Old Sep 26, 2012 | 09:49 AM
krtme's Avatar
Ok guys thanks for your input I will give it a go and post back how I get on
Old Oct 7, 2012 | 01:26 PM
krtme's Avatar
Ok, so re-read the thread from Ceddy over on Geekmapped and then sat down with the laptop and did some work today, flashed the TME with the Ralliart files from Ceddy and after checking a few things started the car up.
All is working as expected, so now to setup my LC1 with the laptop and start to do some proper logging and adjustments.
One thing I would like to know is can you replace the standard narrowband lamda with a wideband and configure the stock ECU to us that for closed loop?
Old Oct 13, 2012 | 01:05 PM
krtme's Avatar
Right guys, I have just bought myself a micro SD card so that I can log the car whilst driving around without the laptop connected. Could somebody have a quick look and see if I have created it correctly? Especially the Injector Duty section.
Thanks,
Keith
File Type: txt
Old Nov 2, 2012 | 08:04 AM
krtme's Avatar
Can anybody help me create a logcfg file to log the correct values please?
Thanks,
Keith
Old Nov 3, 2012 | 12:02 PM
todd6027's Avatar
Thanks,
Keith
this might help
https://www.evolutionm.net/forums/ec...ogcfg-txt.html
Old Nov 3, 2012 | 01:04 PM
krtme's Avatar
Yes I had read that thread, created my own file and just wanted to see if anybody would comment on my config file really.
Also I have noticed that my 1byteload and 2byteload values are way off, how do I find out if I need to make any changes to my MUT table for these values for the TME ecu? I am using Ceddy's xml file. I have read a few threads on here where people have been told to check that MUT41?? has the correct value.
I also seem to be logging different values ignition advance vs ignition map values, and again I have read a few threads but nothing specific to the TME rom.
Anybody got any ideas?
Thanks,
Keith
Old Nov 3, 2012 | 01:07 PM
todd6027's Avatar
what do you have for mut00 and mut01 ,,, rom id ???
Old Nov 3, 2012 | 01:14 PM
krtme's Avatar
rom id 25570100
Model H8539FA
I have attached a screen shot of my MUT table
Thanks,
Keith
Old Nov 3, 2012 | 01:21 PM
todd6027's Avatar
that looks ok did you download ceddy xml for evoscan send me your e mail address il send it over
Old Nov 3, 2012 | 01:24 PM
krtme's Avatar
Hi yes I downloaded the full zip file, and renamed my old xml before copying the Ceddy modified xml over to EcuFlash. I also an running Evoscan 2.9 which has the xml pre-loaded for Ceddy's xml file.
I can upload a log file and my version of the xml if you like? Only just starting out with this so may not have everything sorted yet as I am just logging and making small changes at the moment. Running on 99 RON fuel here in the UK.
Keith
Old Nov 3, 2012 | 01:32 PM
todd6027's Avatar
in evoscan device set up top left are you using mitsubishi mut III
1 byte is request mut41 and function 1.2*x
2 byte mut 00 0.31258*
Old Nov 3, 2012 | 01:45 PM
krtme's Avatar
Attached are my files:
Looks like my evoscan stuff is incorrect though?
File Type: zip
File Type: hex
Old Nov 3, 2012 | 02:30 PM
todd6027's Avatar
looks a bit odd alright il check a ceddy mod evo 6 with evoscan 2.9 on monday see if it logs load correctly
Old Nov 3, 2012 | 02:38 PM
krtme's Avatar
Thanks for that, I look forward to your reply.
I don't suppose you have any ignition maps that I could look at from cars running 98-99 Octane fuel?
Keith
Old Nov 3, 2012 | 02:41 PM
todd6027's Avatar
sure do courtesy of gm attached
File Type: hex
