ecuflash max load changes question
Old Sep 30, 2012 | 09:19 PM
gctech's Avatar
Hi
Im running tephra v7 rom , i cant log passed 30psi in evo scan, I was reading I have to setup the load factor in ecuflash and evoscan, I have set evoscan to my max load but is this the correct place to change the max loadfactor in ecuflash xml ?
<scaling name="Load" units="LOAD kPa" toexpr="x*10/32" frexpr="x*32/10" format="%.0f" min="0" max="300" inc="1" storagetype="uint16" endian="big"/>
I simply put my max load in place of the "300"?
Thanks
Old Sep 30, 2012 | 09:26 PM
gctech's Avatar
Is this the correct way of doing it
https://www.evolutionm.net/forums/8015158-post8.html
Old Sep 30, 2012 | 10:29 PM
07EvoIX's Avatar
what is the max load you are hitting?
to calculate the load factor it is simply 255/max load hit.
so a factor of 1.2 will get you a max load of 306. if you need more, then you need to adjust the load facotr in thr ROM and the formula in evoscan
cheers
mrfred
Feb 26, 2022 06:16 PM
ptm5070
Dec 18, 2014 09:06 AM
erggy
May 2, 2014 01:11 AM
Piper747
Oct 9, 2010 01:14 PM
5LEEPERISAH23I
May 17, 2010 09:54 AM
