Evoscan not logging LoadCalc after rescaling on EcuFlash
Old Mar 24, 2014 | 08:59 AM
erggy's Avatar
Hi all... quick question if i may...
I just recently rescaled load on my evo8MR to max out at 300 (from 260) and flashed that back to my ECU using ECUFlash as I have just upgraded my injectors to 1200cc and tune with E85
Now that I've done a couple of data-logs on EvoScan I've just noticed that my LoadCalc values are showing 0s for all data points!
Any help would be much appreciated please... thank you
Old Mar 24, 2014 | 12:39 PM
jrainwater's Avatar
Did you change the injector scaling on evoscan main screen after you changed the injectors? I know its like "Duh" but maybe you just forgot to do it??
Old Mar 24, 2014 | 04:32 PM
erggy's Avatar
Hi.sorry... I did changed to 713cc on main evoscan..is that whats causing the issue? It was at default previously which did allow evoscan to log loadcalc but the numbers were off as i have changed injectors
Old Mar 25, 2014 | 11:15 AM
jrainwater's Avatar
No, I change mine to the current Rom's scaling and it logs fine. Just wanted to make sure you didn't still have factory in there. Just tossing out ideas.
Old May 2, 2014 | 01:11 AM
superkizuna's Avatar
2-byte load........
search for it on here; that should do it bro.
raza21_84
Apr 3, 2013 06:14 PM
silverstream
Aug 20, 2011 05:16 PM
scherejs
Oct 25, 2010 07:46 PM
racer135
Apr 17, 2008 06:36 AM
bboy
Apr 10, 2008 10:29 AM
