NLTS Problems??
Old Oct 11, 2012 | 06:15 PM
4g63kid's Avatar
NLTS Problems??
Hey all it's been a while since iv been on here and figured its about time to start up again.
Ok so I'm having some trouble getting my nlts working, I was wondering if anyone has experienced similar issues or has a fix for my problem. First off my ecu is 88590015 and I'm using an older version of ecuflash 1.29 to be correct. Iv been lazy about getting another cable and this is the only version that will work with that cable. Iv patched in the tephramod v5.10 to get all the extra options.
I have everything in ecuflash and I have the nlts enabled and the peramiters are set correctly,
Iv tried the not moving test set everything where it needs to be but when I give the car gas and put in the clutch the rpms stay where they are they don't drop like they should. Iv also tried the settings for driving in 3rd gear, wot clutch in and the revs fly so it's not working at all.
Iv been researching all day and I haven't found a fix. Iv read a lot about the clutch switch. My car has both the top and bottom and I'm figuring they work fine, I kno I can only start my car with the clutch pressed in so the top clutch switch must me working but is there still something I'm missing or in particular with the bottom clutch switch.
Now I haven't done anything as far as grounding switches or changing pins in the ecu,, iv read a little about this too but the information is spotty and I can't seem to get a real answer on how to fix this.
I'd like to get the nlts set up and working correctly so if anyone has had this problem how did you get it working???!! Thanks
HyperDisorder
Feb 14, 2017 04:59 PM
taylorgang
Apr 9, 2014 03:30 AM
scheides
Mar 1, 2014 09:45 AM
4g63kid
Jun 18, 2013 07:17 PM
tephra
Jul 16, 2011 04:25 PM
