what do I need for ecu controlled boost
Old Oct 14, 2012 | 03:54 AM
stunt2's Avatar
as above, what do I need guys ? just 3 port solenoid ?
I have evo4(with evo8 ecu) that has no map sensor, do I need that too ?
not for boost logging, just want to run ecu controlled boost
does it make sence to rely on the boost gauge only ? wouild it be hard to tune the boost that way
Old Oct 14, 2012 | 05:20 AM
dolphin888's Avatar
https://www.evolutionm.net/forums/ec...t-control.html
Read twice
Old Oct 14, 2012 | 05:38 AM
stunt2's Avatar
1) A JDM MAP sensor is needed for boost measurement/control.
so have no chance without one
IV's manifolds doesn't even have the port for the map sensor
Old Oct 14, 2012 | 07:00 AM
todd6027's Avatar
you can get an adapter with a tail to mount the map sensor then use a feed pipe from manifold to tail.
like this
http://www.ebay.com/itm/JM-Fabricati...3d6c1a&vxp=mtr
Old Oct 14, 2012 | 07:58 AM
dolphin888's Avatar
This isn't a problem at all, you can always connect GM 3BAR or similar MAP sensor into FPR vacuum line, it's the same way, as you would connect boost gauge, or EBC.
Old Oct 14, 2012 | 08:35 AM
stunt2's Avatar
thanks guys
it's clear now
FL_SilverEvo8
Jan 1, 2015 12:08 PM
racer135
Nov 19, 2008 06:30 AM
nj1266
Apr 6, 2007 08:10 PM
cityhugo
39
Nov 9, 2003 12:16 PM
EvolutionBoy67
Oct 17, 2003 10:58 AM
