Yet another ecu wont read
Old Oct 19, 2012 | 03:29 PM
dsmmk4's Avatar
After doing alot of reading, i still cant figure this out. I have good battery voltage, running ecu unlocker, awaiting my reflash plug but i have a jumper for the timing being i know is making a good connection. picked up a openport 2.0 off a friend of a friend, the led cycles colors while plugged in, blue and green i beleive( color blind, haha) ecuflash in the bottom right corner says its connected via com3 but i just cant read ecu:/ running windows 7 with usb selective suspension disable. After install of ecu unlocker it went a step further, but still failed to work. Is my cable bad? running the most up to date version of ecuflash. If it helps any, mitsulogger 2.0 wont detect vehicle either. thanks for any info in advance!
Old Oct 19, 2012 | 07:56 PM
07EvoIX's Avatar
what the error message?
have you tried using EvoScan to read?
cheers
Old Oct 19, 2012 | 08:15 PM
dsmmk4's Avatar
[17:21:44.586] sending init sequence 1 (0001)
[17:21:47.847] sending init sequence 1 (0003)
[17:21:51.107] sending init sequence 1 (FFFF)
[17:21:53.853] no response to any known code
[17:21:53.853] interface close
Im going to refrain from paying for evoscan untill i come up with some sort of resolution
Old Oct 20, 2012 | 11:17 AM
todd6027's Avatar
run unlocker then open ecuflash then try with unlocker running it should send init seq1 (fofo)
Old Oct 20, 2012 | 01:27 PM
Boosted Tuning's Avatar
I would guess its the lack of a reflash plug or the jumper isnt wired right.
Old Oct 20, 2012 | 04:00 PM
Benja's Avatar
If the re-flash connector is plugged in, I'd say the init string has been altered/ running ECUtek.
Run the unlocked as above.
stokEd
16
Nov 26, 2025 01:12 AM
Mitsu.kid.02
Lancer Engine Management / Tuning Forums
Jan 23, 2014 11:10 AM
Mattsubishi
Apr 13, 2013 11:36 AM
bleunetizen
Feb 20, 2011 01:19 PM
tboboy
Apr 26, 2010 11:47 AM
