New EVODROID7 EvoScan Android GPS/Logger/Reflashing CarPC Touchscreen Review
Old Oct 31, 2012 | 09:05 AM
  #31
mrfred's Avatar
Originally Posted by evoscan
the EvoDroid7 fits in my glovebox easily face down, and I even have torches and tools and all sorts in there too.
Looks kinda big to easily fit in there, but the price is amazing. Is the display itself 18x11 cm or is the size of the unit 18x11 cm? Can it be used with the external ADC cable that you have?
Old Oct 31, 2012 | 03:18 PM
  #32
osetsky's Avatar
Pre-ordered. Screwed up and forgot to add the 1.3 cable in the order. Blast!
Old Nov 1, 2012 | 07:02 PM
  #33
dr_latino999's Avatar
Veteran: Army
I want to pre-order the cable to use in a 3000 mile cross country drive for some long distance logging, but will it be at our doorsteps by Dec 13?
Old Nov 2, 2012 | 02:11 AM
  #34
justastockevo's Avatar
iphones are for p**sies who never give a damn about the tech and want to look geeky.
i want an apk, got too many android devices lying around already. will it work with bluetooth/wifi obd2 dongle and which one i'd need?
Old Nov 2, 2012 | 02:31 AM
  #35
Gsxtremedsm's Avatar
Ok, it's late and I prolly just didn't read close enough.. so I already have the openport 1.3u cable and an android tablet and a galaxy s3..
Can I use any of these? or would I still need to buy your tablet and extra cable?
Old Nov 2, 2012 | 04:36 AM
  #36
dolphin888's Avatar
Originally Posted by justastockevo
i want an apk
I want apk too, I'm not going to buy additional device, I am satisfied with what I have.
I have OTG USB cable and OP 2.0
Old Nov 2, 2012 | 08:35 AM
  #37
vmrevo9's Avatar
Veteran: Air Force
Pm sent!
Old Nov 2, 2012 | 10:07 AM
  #38
Ian0611's Avatar
Maybe I missed it somewhere, but are we able to reflash with this as well or only do logging right now? What program does it (or will it) use for tuning and reflashing? Evoscan or Ecuflash??
Old Nov 2, 2012 | 04:03 PM
  #39
imAnooblikeU's Avatar
Is the evodroid compatible with Subarus? If not, any plans to add compatibility in the future?
Also, is there any way to connect the DLP IO8 to this?
Old Nov 3, 2012 | 06:08 PM
  #40
evoscan's Avatar
Silver Sponsor
looks to me kinda like it will easily fit in there.. yep I tried it at again.. fits super easy. its super thin. yes the size of the unit is 18x11cm, lol one of the biggest requests with the 5inch gpsnav, was can it be a little bigger, ahaha.
there is no such thing as an "external ADC cable", I think you are referring to the openport 1.3DA or openport 3.0DA cable which both have 4x ADC 0-5v input channels.
and yes you can use it as a straight 4 channel ADC datalogger if you like using either of the Openport 1.3DA or 3.0DA cables. but you will need to get power to the device through the OBDII port though, for example pin16(12v +) and pin4(-ve) on openport obd connect need to be powered.
if you give me more details on what you are trying to log with the ADC and are you running this for an EvoX or Evo7/8/9 perhaps? I can give you more specific ideas.
Old Nov 3, 2012 | 06:12 PM
  #41
evoscan's Avatar
Silver Sponsor
Can this be adapted to work on a smaller display, e.g., a 4.3" display smartphone? Would like to have something I can store in my glovebox and pull out when needed.
yes it works on any resolution, the existing gauge designer program still works, so you can edit any design you like for any resolution. it outputs a txt file with the resolution in the filename, for example 800x480_Carbon1.txt and 480x800_Carbon1.txt and you can have any background image filename you like.
Old Nov 4, 2012 | 03:39 AM
  #42
evoscan's Avatar
Silver Sponsor
you have PM, you can pay directly to evoscan paypal and I'll update your order. oh, and by the way, its called an EvoScan OpenPort 1.3DA cable.
Old Nov 4, 2012 | 04:52 AM
  #43
evoscan's Avatar
Silver Sponsor
yes, if it becomes very popular for Mitsubishi Evo, then we will also extend out to Subaru also.
you don't need the DLP-IO8 because it is an all in one solution now, which means you can use the new openport cable in place of the dlp-io8
the EvoScan Openport 1.3DA and 3.0DA has 6 connections, 4 for external devices... 1 for sensor/serial ground (negative) and 5v for powering certain sensors than need 5volts.
1. ADC (0-5v Sensor input) also works as a switch input or switch output.
2. ADC (0-5v Sensor input) also works as a switch input or switch output.
3. ADC (0-5v Sensor input) also works as a switch input or switch output.
4. ADC (0-5v Sensor input) also works as a switch input or switch output.
any of the above 4 can also be used for Serial Input from a Wideband, up to a maximum of 4 widebands connected at once.
5. Ground (for Sensors and Serial Wideband input)
6. 5v Power for powered sensors.
Old Nov 5, 2012 | 07:54 AM
  #44
RobCrezz's Avatar
Is there any way you can make it have the option to give a MPH speed reading (even if the speedo reads in kmh)?
Nice work by the way.
Old Nov 5, 2012 | 10:56 AM
  #45
chu's Avatar
chu
Hamish, I jsut want some clarification whether the 3.0DA cable will also work for CT9A platform? I'm ready to order, and would like to order the 3.0DA if it is a more universal application.
