New EVODROID7 EvoScan Android GPS/Logger/Reflashing CarPC Touchscreen Review
Old Dec 10, 2012 | 03:47 PM
  #91
maximusnz's Avatar
Originally Posted by limaynard
So, any news on shipping date?
thanks...
+1
Since xmas is around the corner... those who have paid their pre orders will get their Evodroid before xmas?
Old Dec 14, 2012 | 01:00 PM
  #92
limaynard's Avatar
Any update?
It would be good to know whether it will be here before Christmas or not.
Thank you...
Old Dec 17, 2012 | 07:40 AM
  #93
chu's Avatar
chu
These guys must be super busy packaging the orders for shipment!
Anyone else thought of fix-mounting the unit using a double din panel? I plan to try that when the unit arrives.
Old Dec 17, 2012 | 04:00 PM
  #94
slix_88's Avatar
Ordered one
Just a couple questions which may have already been answered in this thread.
- Could the cable supplied be used to tune the car?
- Silly question, but how would I be able to connect this unit up to the ECU. I've searched these forums but haven't been able to find a guide on where the cable should be connected. Images would be helpful.
- (depending on previous question) What's the easiest way to get the cable connected?
For the time-being, I will only use the system to log metrics from my vehicle.
If you didn't realise already, I'm completely new to Evos.
Old Dec 17, 2012 | 05:09 PM
  #95
limaynard's Avatar
Hi, as far as I understand it the DA cable supplied is for Datalogging for the Android tablet only.
If you want to flash the ECU you will need another cable (Openport 2.0) is what I use. It is best to get it from Tactrix website, mine took about 3 days to get from San Fran to Sydney. I use ECUFlash to tune.
The Evodroid DA cable connects to the OBD port under the steering wheel. I suspect you will only need to do this - unless you want to log boost from a MAP sensor or log from a wideband sensor etc, in which case you connect to the Evodroid cable.
Old Dec 17, 2012 | 05:11 PM
  #96
limaynard's Avatar
It is also cheaper to get direct from Tactrix - you can get them on eBay for double the price!!
Old Dec 17, 2012 | 05:32 PM
  #97
chu's Avatar
chu
Probably should have researched a little more before you ordered... But I tried answering the questions.
Originally Posted by slix_88
Ordered one
As of right now, the 1.3DA and 2.0DA cables can only be used for logging. Flashing capabilities will come at a later time in more updated versions, which will be free. Stay tune for that.
The cables is connected via the OBD-II ports inside the car. You can search OBD-II connector to see what they look like. There's no wiring to the ECU necessary.
Cables only go in one way.
Old Dec 17, 2012 | 08:00 PM
  #98
slix_88's Avatar
Cheers for the help guys! Much appreciated.
I was after something to give me a log of my car's metrics as a starter; no need to tune yet.
I'm still new to the Evo and again I appreciate your patience with me. Just another question; if I connect to the OBD port, will I get a boost reading too?
With my question about the easiest way to connect, now that I know it's under the steering wheel, I just need to find a way to neatly connect it.
Old Dec 17, 2012 | 10:18 PM
  #99
GregM's Avatar
Could you record the gauges so that you can overlay it on other video?
Old Dec 17, 2012 | 11:08 PM
  #100
limaynard's Avatar
From Evoscan you can get a right angle extension cable that will make it neater.
As for logging boost, there are two ways.
1. Get a 3 bar MAP sensor and mod the ECU to log boost.
2. Get an external 3 bar MAP sensor and wire this into the Evodroid cable.
Good luck....
I will be attempting to wire an external MAP sensor to log boost when mine arrives.
Old Dec 17, 2012 | 11:30 PM
  #101
GregM's Avatar
Heres a plan, hopefully this will work. Galaxy S3, running Screencast, have Evoscan not save to file, and run gauges. Record gauges and also use the GoPro app to start my cameras. With any luck I'll have a video of my gauges, not too far out of sync with my GoPro's, and can overlay the gauge video over the GoPro footage. As soon as the cable and software are available, I'll give this a try as long as this is not shot down.
Old Dec 18, 2012 | 01:08 AM
  #102
limaynard's Avatar
Greg, sounds a bit 'Heath Robinson'
Is there an option / android app to do a screen capture to video? I'm not an Android person so have no idea..
Old Dec 18, 2012 | 10:04 AM
  #103
GregM's Avatar
Yea, found Screen cast will do it, just need to root my phone. I may try it out using my laptop, get Camtasia or something to capture the gauges and have a play overlaying them.
Old Dec 18, 2012 | 04:56 PM
  #104
limaynard's Avatar
Still no word on shipping date. I can only assume that it will now be after Christmas
Old Dec 18, 2012 | 06:56 PM
  #105
gotpsi?'s Avatar
Bummer. Should get a partial refund.
