New EVODROID7 EvoScan Android GPS/Logger/Reflashing CarPC Touchscreen Review
Old Oct 10, 2013 | 12:44 PM
  #841
evoscan's Avatar
Silver Sponsor
I wouldn't use the word "flashing" that is reserved for re-flashing. I would use the term "mut diagnostic mode"
thats because you were using a 1.3R or 1.3U cable before.. whereas 1.3D and 1.3DA both set the ecu to "mut diagnostic mode", always have. It is for maximum compatibility with 1992-1998 mitsubishi vehicles. without "mut diagnostic mode" for them datalogging is impossible. if you like to stop the CEL lights from flashing like the 1.3R/1.3U cables do.. then you can disconnect obdii pin1 safely. it does nothing other than sets ecu to"mut diagnostic mode".
Old Oct 10, 2013 | 12:50 PM
  #842
evoscan's Avatar
Silver Sponsor
all the 1.3R and 1.3U cables do is toggle the pin1 on the OBDII to ground or not.. to set the "mut diagnostic mode" . I could look into a toggle setting for you that can toggle the pin1 from software. I don't notice it on my evo8 because I disconnected my pin1 a long time ago for this reason.
Old Oct 10, 2013 | 01:02 PM
  #843
EVOMIZ's Avatar
Error null pointer exception
Error mitsu mutii acd 7-8-9unknown host expection unable to resolve host
Error missing data file mitsu mutii acd
Old Oct 10, 2013 | 01:07 PM
  #844
evoscan's Avatar
Silver Sponsor
Originally Posted by EVOMIZ
Error null pointer excetion
unable to resolve host, means that you have no dns host resolve . i.e there is no wifi turned on. because it connects to the website to get the latest xml file for that datasettings xml file.
Old Oct 11, 2013 | 07:24 AM
  #845
EVOMIZ's Avatar
Ok so now I have it connected to the car all I can get to read is battery and tps
looked at the settings and checked speed and it does nothing.
also what are all the other sensors for ?
Old Oct 11, 2013 | 08:46 AM
  #846
Mitsu-Beasty's Avatar
evoscan PPC
hey hamish i sent a trouble ticket on evoscan.com to be added to the gps nav group, it wont allow me to download the PPC from the website keeps erroring out saying i dont have access to the group. TT# WEJ7JTB6D2
Old Oct 11, 2013 | 10:38 PM
  #847
limaynard's Avatar
Hamish, I am ready to give up too....
I fried the evodroid - my fault I know, got a new cable and a new Samsung tablet. I am still waiting to get a copy of the software (I have a copy but that's not the point) and now on my new Samsung Galaxy Tab 3 it works (in that it connects and logs) but I can't select any of the log items in the list....
I select them, exit out of the screen (by pressing the back button as that's the only way to do it) and when I go back in they are not ticked.
The multiple templates 'function' also doesn't work (but you know this).
You know, I am a big supporter - I am currently helping others build templates but at present I can't use the thing...
Come on, help would be nice...
Old Oct 11, 2013 | 10:51 PM
  #848
limaynard's Avatar
Okay, I may have ranted too soon.
By entering the screen, double clicking on the data item (so that it shows as checked, then unchecked) and then exiting they stay checked....
A bit of a workaround but I am going to try it now.
Old Oct 11, 2013 | 11:05 PM
  #849
Grimgrak's Avatar
Dont give up bro, I'm counting on you once christmas break comes around and I actually attempt to wire up my external sensors!
Old Oct 12, 2013 | 04:36 AM
  #850
evoscan's Avatar
Silver Sponsor
PPC stands for Microsoft Windows Mobile PocketPC... that is nothing to do with Android and Evodroid7.
Old Oct 12, 2013 | 04:41 AM
  #851
evoscan's Avatar
Silver Sponsor
Ticking the dataitems on the EvoDroid7 works when I test it. sorry I don't have a Samsung Galaxy Tab 3 to test with, I already guessed every android device would behave differently. That's why it is best to use the included EvoDroid7.
Old Oct 12, 2013 | 01:08 PM
  #852
limaynard's Avatar
Hamish, you are correct. I wouldn't expect it all to work with any device, my apologies.
Look on it as additional certification testing!
There are still some other issues though such as access to re download the software, maybe with a disclaimer around potential issues with different devices.
There is also the template switching.
Also it would be good tohave a known issues list.
Thanks for everything.
Old Oct 12, 2013 | 01:59 PM
  #853
limaynard's Avatar
New thread started on EvoDroid Gauges...
https://www.evolutionm.net/forums/ec...l#post10986407
Old Oct 14, 2013 | 05:18 PM
  #854
jdmevorory's Avatar
the 1.3DA cable and evodroid7 will work on a Subaru, but only once I have added an update to the software to enable it.. currently it is not enabled due to it needing a bit more android java programming. It is on the roadmap to complete the programming update for the subbie. not sure when it will be released at this stage.
I look forward to the update! Would some extra money help with it ?
Old Oct 14, 2013 | 06:02 PM
  #855
limaynard's Avatar
Has anyone got a wideband working with this?
i can get the wideband working if I use the 0-5v output but it needs to be calibrated so is way off. I have tried using the serial cable but with no luck.
