Search Patch for Boost Map in each Gear (96530006)
Old Oct 26, 2012 | 02:45 PM
Lancer_Evo_8's Avatar
Maybe somebody can help me.
Im searching for a patch or just fore some help to edit my boost specific in every gear.
Someting like this here:
Old Oct 26, 2012 | 04:22 PM
japanevo's Avatar
Far as I know the only way you can get gear dependant boost is to download a complete Tephra7 rom. I don't think there is a patch just for that function.
Old Oct 27, 2012 | 09:25 AM
And how can help me to find complete Tephra7 96530006 rom?
Old Oct 27, 2012 | 10:43 AM
Boosted Tuning's Avatar
Google "Tephra V7" and it comes right up.
https://www.evolutionm.net/forums/ec...hramod-v7.html
Old Oct 28, 2012 | 02:15 AM
Sorry but maybe im too stupid , i tried to do it but
I downloaded this xml here:
Option 4 96530706 (v7 + Mods) - Download | Mirror
  • Set Immob. HEX to 0x0040 (check to make sure your old ROM was the same)
  • mrfred psi based boost implemented as default (just edit Tephra's gear dependant map)
  • OBD II Inspection ready for EVAP and EGR
  • Disabled EGR, EVAP, and Idle Tests
  • Disabled P0300 code
  • Disabled lean spool
  • mrfred double fuel cut load limit implmeneted and set to 300 load (change to whatever you need this to be, read more)
Then i copy this file "TephraMOD-96530706-v7.xml" here: C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
But if i open my Ecuflash there is nothing about gear dependant boost.
Is there something i forgot to do?
Old Oct 29, 2012 | 09:41 AM
japanevo's Avatar
did you down load the .bin file as well or are you using your factory .bin. It wont work without downloading the rom that is linked in that thread as well.
Old Oct 30, 2012 | 11:40 AM
Sorry for al my Questions
1. Yes im working still with my factory Bin. But where i can find the bin file i need?
2. Why not? What i have to do more?
Old Nov 8, 2012 | 09:26 PM
japanevo's Avatar
Sorry for the delay. Basicly the patch you are looking for was custom programmed into that specific group of roms known as Tephra mods, it was never something that was included from the factory. The only way to get that function is to download one of Tephra's roms and the accompanying ".XML"s so that you can tune it...
Old Nov 9, 2012 | 01:26 PM
@ japanevo
Do you know which tephra i have to search or download?
Old Nov 9, 2012 | 04:39 PM
japanevo's Avatar
You already found it... You can use either option 1 or option 4, option 4 just has some other things done to it already.
https://www.evolutionm.net/forums/7597107-post2.html
Old Nov 10, 2012 | 12:31 PM
@ japanevo
Now i realised this. All the new tables of tephra are unlocked. Thnak you first of all!
But its normaly that now i have some double tables? For example, i have two times the "rev limit table" but one time in MPH and one time in Km/h. And i need just the one with Km/h.
The tables how i dont need i have to delete (always one successively)?
Old Nov 10, 2012 | 11:01 PM
japanevo's Avatar
@ japanevo
Did you mod your old .XML by adding the information from .XML that was included with the download? Or did you just paste .XML that came with the ROM into the ECUflash directory? There shouldn't have been any double tables in the .XML that came with the Tephra mod. None that I saw anyway.
Old Nov 11, 2012 | 02:39 AM
No, i didnt mod my old .XML, i just paste the Tephra xml File in the rommetadata/mitusbishi/evo
But now i have 3 times almost the same file. I have to delete one or two files?
Old Nov 11, 2012 | 08:50 PM
japanevo's Avatar
Ya you should be able to to get ride of those other XMLs. I would move them to your "My Documents" folder and hang on to them just in case...
Old Nov 13, 2012 | 10:06 AM
Now i have just one xml File in my EVO rommetadata with the ECU ID 96530006 . All others xml File with the Number "96530006" i delete. But i Still have a lot of double tables. Do i something wrong?
I have for example double tables of:
- MUT Table
- spray on Knock time
- KnockSum Required for Slow CEL
- all IC Relay tables
- periphery
- and more others
