Adding second map sensor
Old Oct 27, 2012 | 06:53 AM
211Ratsbud's Avatar
Can I use the rest of the maf harness to configure and log a second map sensor? I'm on sd using gm iat.
I want to log pre throttle body pressure.
Old Oct 27, 2012 | 08:05 AM
donner's Avatar
According to workshop manuals both baro and map inputs seems to be same type inputs so maybe you could use baro analog input directly? As you know there is all necessary signals in maf connector for map sensor: +5V, ground and signal wire (baro) connected to analog input pin. So we just need to point one unused adc read routine to read baro input.
This is for 88586714 (logging from MUT97):
<table name="Read baro ADC (0x08 -> 0x04)" category="Speed Density Programming" address="bf99" type="1D" level="1" scaling="Hex8"/>
Old Oct 27, 2012 | 01:21 PM
todd6027's Avatar
Do you have same for 88570008 ??? please and thanks
Old Oct 27, 2012 | 01:48 PM
211Ratsbud's Avatar
Thank you donner, I will be trying to accomplish adding a second map sensor to compliment the sas theory that I have going.
Old Oct 27, 2012 | 09:30 PM
211Ratsbud's Avatar
Is there any difference in logging the compressor cover vs just pre throttle body?
Old Oct 27, 2012 | 11:50 PM
donner's Avatar
Remember this only works with sd roms
For 88570008 (logging from MUT97):
<table name="Read baro ADC (0x08 -> 0x04)" category="Speed Density Programming" address="b301" type="1D" level="1" scaling="Hex8"/>
Old Oct 28, 2012 | 12:58 PM
todd6027's Avatar
perfect , thats understood , many thanks
Old Oct 29, 2012 | 07:15 AM
211Ratsbud's Avatar
Todd do you plan to add a map sensor or something else?
Old Oct 29, 2012 | 11:16 AM
todd6027's Avatar
for the min i want to try use it to log charge temp
Old Oct 30, 2012 | 12:34 PM
Nimpoc's Avatar
If you're not running a gang of boost, these sensors look pretty sweet; and cheap!
Bosch 3 Bar TMap Map Sensor with IAT: $30
http://www.bmotorsports.com/shop/pro...oducts_id/1721
4-way sealed Plug Bosch BSK Connector Kit for Bosch MAP Sensor: $20
http://www.bmotorsports.com/shop/pro...oducts_id/1625
They seem like a real good option for retrofitting for SD in general. The sensor has a bunch of resolution on the bottom of the MAP range for good idle, etc.
Old Oct 30, 2012 | 12:58 PM
211Ratsbud's Avatar
I have one wrx 2.5l sensor 2.5 bar looks pretty close that
Old Nov 22, 2012 | 05:58 PM
211Ratsbud's Avatar
Ok, so I can just splice the output wire from the MAP sensor in to pin 2 on the maf plug im good right?
sensor gets ground and +5v for power which should be ok to split from the IAT sensor correct?
Attached Thumbnails Adding second map sensor-mafs.png   Adding second map sensor-maf.gif
Old Nov 22, 2012 | 07:42 PM
Dynotech Tuning's Avatar
I would like to start logging dual boost to get some turbo back pressure data. This would be helpful.
Old Nov 22, 2012 | 09:47 PM
211Ratsbud's Avatar
Im torn in mounting location. No matter what aluminum must be modified. Are you thinking pre and post IC locations?
LuckyManiac
Jun 26, 2017 03:45 PM
duranvw
Oct 19, 2016 11:36 AM
jameswwt
Sep 18, 2015 05:49 AM
Dibzy360
May 17, 2013 10:02 PM
jmelocik
12
Jan 31, 2009 02:26 PM
