Question for you full open loop tuners
Old Nov 12, 2012 | 06:55 AM
duranvw's Avatar
Hey guys,
I drive a IX, I suspect I'm having some problems with an o2 sensor as the car gets very rich at idle. I do plan on replacing the sensor however I need to drive the car right now.
I have flashed a full open loop tune using the FAA bit option. I drove around the block and found the AFRs at idle/cruise were a bit richer than the desired 14.7. I was getting around 13.8, now my question is do I just work inside of the High and Low Octate Fuel Map in ECUFlash to correct this? I know I need to be working under 80 load and 4500 RPM range.
Do I just continue to increase the cells from 14.7 higher until I reach the desired crusie AFR? I have already changed all the cells from 14.7 to 15.7 without a huge noticable change in my AFRs.
Is there another table I shuold also be worknig on to adjust this or just increase this higher than 15.7?
Thanks guys.
Old Nov 12, 2012 | 07:18 AM
Biggy VIII's Avatar
I would lower the latency of injectors just a bit if you are a little on the rich side at idle\cruise.
Old Nov 12, 2012 | 08:00 AM
duranvw's Avatar
Which tables would I use to modify this? How much of a change should I look to make?
Old Nov 13, 2012 | 08:58 AM
Biggy VIII's Avatar
"Injector Battery Voltage Latency Compensation" table.
you need to lower it just a bit.
for example if your latency at 12 and 14 volt set
1.248
0.984
lower them just 1 step down to
1.224
0.960
keep an eye on your AFR gauge.
Old Nov 13, 2012 | 10:00 AM
duranvw's Avatar
Ok that's what I was thinking from reading some threads on tuning injectors.
This is my current voltate latency. I guess I would want to start adjusting the entries across from 11.72 and 14.06 volts, is this where the voltage would be when the car is at idle or cruise? I would want to focus in that area
1.248
0.984
1.224
0.960
Old Nov 13, 2012 | 12:20 PM
Biggy VIII's Avatar
yes. but you should keep the curve. if your changes are substantial, than you should correct the adjacent cells in that table too.
Appauldd
Sep 21, 2015 08:39 AM
mines5
16
Jul 1, 2014 10:09 PM
stunt2
Mar 19, 2011 05:04 PM
Mitsu.kid.02
Lancer Engine Management / Tuning Forums
23
Nov 5, 2010 03:45 PM
SeanV
Oct 7, 2009 09:35 AM
