AFR @ 14.2+ at WOT - EFFECTS?! need help!
Old Nov 11, 2012 | 04:20 PM
filipec's Avatar
Hi all,
I'm modding my 2012 2.0 NA Lancer and struggling to get more power from it.
So far, I've made the following changes and got the following results:
Stock (baseline): 134whp
ECU Tune V1 by Ralliinspired Rick: 140whp
ECU Tune V2 by Ralliinspired Rick: 142whp
+4g69 throttle bodie: 144whp
+Hi-flow metalic Cat + catback exhaust (2.5in): 149whp
+Takeda SRI: 150whp
The thing is, I was expecting around 160whp at this point... and the car is running lean, around 14.2+ AFR. Do you guys think I could get more power from richen the AFR?
Also, Rick has done a richier version, but it actually lost power, around 10whp (some areas) and 3whp peak!
See both vídeos:
Stock AFR (ECU tune V2 by rick):
Richer AFR (ECU tune v3 by rick):
The funny thing is, that is possible to see a little "kick" at around 5k, but the dyno showed less power!!
Old Nov 11, 2012 | 07:12 PM
ReaperX's Avatar
I would say for an n/a motor 14.2 @ wot is too lean. Somewhere between 12.5 and 13 is where you'd want to be.
Old Nov 12, 2012 | 05:21 PM
todd6027's Avatar
x2
Old Nov 14, 2012 | 07:22 AM
CtSilver03Evo's Avatar
^ What these guys said... Lean is mean, but it's only a matter of time before you burn some pistons/valves at those AFRs
mrm95
May 18, 2015 12:32 AM
marcusE
Jul 2, 2013 07:37 PM
Yiyo
16
Mar 17, 2013 09:36 PM
deukalions14
Oct 6, 2012 10:05 AM
ineedmorepsi
Jun 23, 2012 08:15 AM
