Pop's & Bang's Map...Is it BAD?
Old Nov 20, 2012 | 01:23 PM
  #31
Biggy VIII's Avatar
Originally Posted by domyz
I'm sure that you have more torque for each cell but if it takes twice the time to load the car, overall torque suffer. Area under the curve ftw
Having more torque means going through revs faster.
Originally Posted by dolphin888
Impressive numbers.
Let's stop OT now:|
agree.
Old Nov 21, 2012 | 07:09 AM
  #32
JSPturbo's Avatar
Which Pressure you have at idle with this timing maps ? Throttle Body closed or partially open ? BOV Recirculated or suppressed ?
I have negative timing on my car in the lower areas and the vaccum is around -17psi at idle. Should ideally have 0 of Pressure at idle for cero Lag !!!
Old Nov 21, 2012 | 07:41 AM
  #33
jameswwt's Avatar
Hi JSPturbo,
mind to share on how to get 0 vacumn on idle?
Thanks
Old Nov 21, 2012 | 07:52 AM
  #34
domyz's Avatar
-17 psi is impossible on this planet. Read more.
-0 pressure for zero lag : you obviously don't understand what is lag. Read more.
Negative pressures
While pressures are, in general, positive, there are several situations in which negative pressures may be encountered:
  • When dealing in relative (gauge) pressures. For instance, an absolute pressure of 80 kPa may be described as a gauge pressure of −21 kPa (i.e., 21 kPa below an atmospheric pressure of 101 kPa).
  • When attractive forces (e.g., van der Waals forces) between the particles of a fluid exceed repulsive forces. Such scenarios are generally unstable since the particles will move closer together until repulsive forces balance attractive forces. Negative pressure exists in the transpiration pull of plants, and is used to suction water even higher than the ten meters that it rises in a pure vacuum.
  • The Casimir effect can create a small attractive force due to interactions with vacuum energy; this force is sometimes termed "vacuum pressure" (not to be confused with the negative gauge pressure of a vacuum).
  • Depending on how the orientation of a surface is chosen, the same distribution of forces may be described either as a positive pressure along one surface normal, or as a negative pressure acting along the opposite surface normal.
  • In the cosmological constant.
Turbo lag
Turbocharger applications can be categorized according to those which require changes in output power (such as automotive) and those which do not (such as marine, aircraft, commercial automotive, industrial, locomotives). While important to varying degrees, turbo lag is most problematic when rapid changes in power output are required.
Turbo lag is the time required to change power output in response to a throttle change, noticed as a hesitation or slowed throttle response when accelerating from idle as compared to a naturally aspirated engine. This is due to the time needed for the exhaust system and turbocharger to generate the required boost. Inertia, friction, and compressor load are the primary contributors to turbo lag. Superchargers do not suffer this problem, because the turbine is eliminated due to the compressor being directly powered by the engine.
Lag can be reduced in a number of ways:
  • lowering the rotational inertia of the turbocharger; for example by using lighter, lower radius parts to allow the spool-up to happen more quickly. Ceramic turbines are of benefit in this regard and or billet compressor wheel.
  • changing the aspect ratio of the turbine.
  • increasing the upper-deck air pressure (compressor discharge) and improving the wastegate response
  • reducing bearing frictional losses (such as by using a foil bearing rather than a conventional oil bearing)
  • using variable-nozzle or twin-scroll turbochargers (discussed below).
  • decreasing the volume of the upper-deck piping.
  • using multiple turbos sequentially or in parallel.
  • using an Antilag system.
Old Nov 21, 2012 | 08:58 AM
  #35
jameswwt's Avatar
+1 to Domyz
Old Nov 21, 2012 | 10:01 PM
  #36
211Ratsbud's Avatar
I have a much improved version of this coming, im just running tight on development funds atm.
I am lacking one final step to my hardware and from ther hopefully just ecu tuning. read more in the thread I have a couple pages back.
Old Nov 22, 2012 | 12:44 AM
  #37
jameswwt's Avatar
Hi 211, mind to share yr thread link.
Old Nov 22, 2012 | 03:02 AM
  #38
jameswwt's Avatar
Hi Domyz,
sorry for the noob question but what does this 2 paragraph mean?
1) increasing the upper-deck air pressure (compressor discharge) and improving the wastegate response :
a) Upper deck air pressure/compressor discharge?
b) What is the best way of improving the WG response?
2) decreasing the volume of the upper-deck piping :
c) Reducing the ic piping size where after the intercooler up to throttle body?
Thanks
Old Nov 22, 2012 | 06:40 AM
  #39
domyz's Avatar
A- higher pressure post compressor will reduce lag...example: small cams/less VE. Obviously not good for power but for lag.
B- tightening wga arm, ebc 100% closed on spoolup.
C- smaller intercooler, tubing. (Less volume so pressure will rise faster)
Old Nov 22, 2012 | 06:56 AM
  #40
Biggy VIII's Avatar
simple things been said using complicated words.
Old Nov 22, 2012 | 07:08 AM
  #41
domyz's Avatar
It was a copy paste from wikipedia
Old Nov 22, 2012 | 07:16 AM
  #42
JSPturbo's Avatar
Depression at idle Sr. With the Throttle Closed. -0.5b - 0.7b or -10psi aprox.
A small video of a Evo IX Friend.
Old Nov 22, 2012 | 08:53 AM
  #43
211Ratsbud's Avatar
I've done this aswell
Need to switch to open loop
Old Nov 22, 2012 | 09:37 AM
  #44
jameswwt's Avatar
Thanks Domyz...
Old Nov 22, 2012 | 09:43 AM
  #45
escodotcarter's Avatar
funny thread
