Disable ltft how to?
Old Dec 23, 2012 | 10:55 AM
211Ratsbud's Avatar
Originally Posted by todd6027
Ive a 9 ecu in an Evo4 with no immobiliser / no rear o2 so im using 56d0
56d0 immo / rear o2 OFF
56da immo / rear o2 ON
56d8 immo ON / rear o2 OFF
56d2 immo OFF / rear o2 ON
52 rather than 56 would be " IGn Timing as map "
16 rather than 56 would be "o2 heater circuit OFF "
So what does ign timing as map mean? I have 52da
Old Dec 23, 2012 | 11:11 AM
todd6027's Avatar
used to be called " disable timing knockdown on light acceleration " set to 0
Old Dec 23, 2012 | 11:39 AM
211Ratsbud's Avatar
Gotcha,
52d0 would be
timing as map immo/o2 both off then
Old Dec 23, 2012 | 11:55 AM
todd6027's Avatar
yep that it
Old Dec 24, 2012 | 07:10 AM
gear head's Avatar
Try this in your xml..
They may help or may not, these tables show both HEX & Bits.
<!-- *** ECU PERIPHERY *** -->
<table name="Disable/Allow P2_FCA, P3_FDA Bits" category="ECU Periphery" address="101C" type="1D" level="4" scaling="uint8"/>
<table name="ECU Periphery00 (F9A)" category="ECU Periphery" address="f9a" type="3D" level="4" scaling="blobbits">
<table name="HEX" address="f9a" type="X Axis" elements="1" scaling="Hex16">
</table>
<table name="Periphery Bit Number" type="Static Y Axis" flipy="true" elements="16">
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<table name="ECU Periphery0 (FAA)" category="ECU Periphery" address="faa" type="3D" level="4" scaling="blobbits">
<table name="HEX" address="faa" type="X Axis" elements="1" scaling="Hex16">
</table>
<data>bit.15</data>
<data>bit.14 : front o2 sensor heater circuit</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11 : 1 = Disable EGR adv</data>
<data>bit.10 : 0 = Disable Unknown Ign Trim</data>
<data>bit.9 : 0 = Disable warmup Ign Retard</data>
<data>bit.8</data>
<data>bit.7 : Enable High Oct Ign Map Lookup</data>
<data>bit.6 : "Enable Speed Limit Test"</data>
<data>bit.5</data>
<data>bit.4 : 0 = Disable Closed Loop</data>
<data>bit.3 : 0 = disable Immobiliser</data>
<data>bit.2</data>
<data>bit.1 : rear o2</data>
<data>bit.0</data>
</table>
</table>
<table name="ECU Periphery1 (FBA)" category="ECU Periphery" address="fba" type="3D" level="4" scaling="blobbits">
<table name="HEX" address="fba" type="X Axis" elements="1" scaling="Hex16">
</table>
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5 : 2nd thermo fan table</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0 : 0 = Disable Lean Spool</data>
</table>
</table>
<table name="ECU Periphery2 (FCA)" category="ECU Periphery" address="fca" type="3D" level="4" scaling="blobbits">
<table name="HEX" address="fca" type="X Axis" elements="1" scaling="Hex16">
</table>
<data>bit.15 : PO443, PO446, PO403, PO243, PO090, P2263</data>
<data>bit.14 : EVAP(PO450-PO453)</data>
<data>bit.13 : EVAP(PO441, PO442)</data>
<data>bit.12</data>
<data>bit.11 : PO031, PO032, PO037, PO038</data>
<data>bit.10 : MAP Sensor(P1400)</data>
<data>bit.9 : 0 = Disable EGR Test(PO401)</data>
<data>bit.8 : 0 = Disable Idle Test(PO506, PO507)</data>
<data>bit.7 : PO170(PO171, PO172)</data>
<data>bit.6 : Front O2(PO134)</data>
<data>bit.5 : 0 = Disable PO300</data>
<data>bit.4 : 0 = Disable PO300</data>
<data>bit.3 : O2(PO132,PO136)</data>
<data>bit.2 : PO133, PO159</data>
<data>bit.1 : PO421(Not In FSM)</data>
<data>bit.0</data>
</table>
</table>
<table name="ECU Periphery3 (FDA)" category="ECU Periphery" address="fda" type="3D" level="4" scaling="blobbits">
<table name="HEX" address="fda" type="X Axis" elements="1" scaling="Hex16">
</table>
<data>bit.15 : CT Below Reg(PO128)</data>
<data>bit.14 : Bat. Backup(P1603)</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11 : PO180-PO183, PO461, P2066(fuel sensors)</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7 : PS Pressure(PO551)</data>
<data>bit.6 : Speed Sensor(PO500)</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2 : PO234, PO243, P2263</data>
<data>bit.1 : PO510(Not In FSM)</data>
<data>bit.0 : P1715, P1750, Etc.</data>
</table>
</table>
<table name="ECU Periphery4 (FEA)" category="ECU Periphery" address="fea" type="3D" level="4" scaling="blobbits">
<table name="HEX" address="fea" type="X Axis" elements="1" scaling="Hex16">
</table>
<data>bit.15 : Rear O2 No Act(PO140)</data>
<data>bit.14 : MAP vs. BARO(PO069)</data>
<data>bit.13 : IAT Circuit(PO111)</data>
<data>bit.12 : PS Pressure sensor(PO554)</data>
<data>bit.11 : A/C 1 Switch(P1530)</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8 : Clutch Pedal Circuit(PO830)</data>
<data>bit.7 : Fuel Pressure Circuit(PO090)</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<table name="ECU Periphery7 Hex" category="ECU Periphery" address="ffa" type="2D" level="1" scaling="Hex16">
<table name="Y" type="Static Y Axis" elements="8">
<data>0xffa</data>
<data>0xffc</data>
<data>0xffe</data>
<data>0x1000</data>
<data>0x1002</data>
<data>0x1004</data>
<data>0x1006</data>
<data>0x1008</data>
</table>
</table>
Old Dec 24, 2012 | 02:51 PM
ExViTermini's Avatar
Originally Posted by JohnBradley
It might be 56D0 which is also the immobiliser. Todd I will look at my notes but I am pretty sure that 56d8 should turn the LTFT off as well. I have them off in my ROMs but I couldnt tell you when I turned it off...or how Well at least for sure.
So is it safe to assume that you simply disable the LTFT in all of your roms and leave them that way? This still has STFT enabled tho as well right?
silentsmoker84
Aug 6, 2024 09:54 AM
Rico8638
Jul 13, 2019 10:29 PM
Dr. EV0
Nov 25, 2014 01:10 PM
_RMC_
Apr 11, 2014 12:33 PM
EVIL_EVO_VIII
Evo X How Tos / Installations
60
Nov 28, 2013 09:32 AM
