Disable ltft how to?
How does one go about disabling long term fuel trims? Tuning in speed density an I'd like to be able to monitor stft so I can play with my maf comp some. JB mentioned doing this and googling didn't turn out even if it was possible
If you were going to add the hex version of Periphery bits of Periphery 0 it would be-
address - FAA
scaling - Hex16
I'd look up whatever 0/1 style bit that controls the rear O2 and turn that one off
I'll dig my laptop out tomorrow and post it.
address - FAA
scaling - Hex16
Ok I have been looking around and searching but got cut short. I came across the detailed periphery bits thread and I'm nearly positive I can find the answer in there for o2 control.
After all this it finally makes sense to me how 2d SD conversion works just as good as a 3d version if you know the nitty gritty. Except 3d can go so far in ve corrections that its exponentially time consuming if you make it. Lol as always the community help is excellent here and thank you all
I've been comparing bits from 8858 which I use and 8859 they look the same after a reasonable glance but ill double check once I find the right bit
Ps you should have a gander at the 88586714 rom , downsized 3d ve table ..
So the 56 - > 52 change was from another bit change and if I just modify the back half of what hex is in there I get the result desired ? Ie da-> d8 essentially stops the ltft + rear o2?
The only thing I have noticed that will make the conversion inaccurate is a poor MAF intake setup with turbulence.
-Jamie
with two threads going, its getting hairy, but I do have v2.9 and I can set up a MAF rom very easily, my MAF is just dehoneycombed so maybe that will hinder things.
I have a fp84 intake tube
It might be 56D0 which is also the immobiliser. Todd I will look at my notes but I am pretty sure that 56d8 should turn the LTFT off as well. I have them off in my ROMs but I couldnt tell you when I turned it off...or how
Well at least for sure.
Ive a 9 ecu in an Evo4 with no immobiliser / no rear o2 so im using 56d0
56d0 immo / rear o2 OFF
56da immo / rear o2 ON
56d8 immo ON / rear o2 OFF
56d2 immo OFF / rear o2 ON
52 rather than 56 would be " IGn Timing as map "
16 rather than 56 would be "o2 heater circuit OFF "
