noob question
Old Jan 17, 2013 | 07:37 AM
jhoganusaf's Avatar
noob question
so i have evoscan 2.9, and im using the factory rom file on my car. how do i log load with out going to a tephra rom?
Old Jan 17, 2013 | 08:32 AM
evo8426's Avatar
Load Calc is available for logging
Old Jan 17, 2013 | 08:34 AM
Raptord's Avatar
You could also configure 2byte load. Doesn't loadcalc cap at 159? Or is that ecuload?
Old Jan 17, 2013 | 08:53 AM
jhoganusaf's Avatar
ill give it a shot. thanks for a fast reply.
Old Jan 17, 2013 | 08:58 AM
evo8426's Avatar
I believe it is ecuload that caps out.
Old Jan 17, 2013 | 09:02 AM
jhoganusaf's Avatar
so while doing some datalogs, i noticed my car is reading timing from the 200-240 cells at wot, but its reading afr 90-100 load. i logged AFR Map in evoscan to see which cells it was reading from. i know that sounds weird.
Old Jan 17, 2013 | 09:53 AM
awadkhan's Avatar
AFR's in the fuel map doesn't always match the actual AFR of the car. Log 2byte and work on the load that it shows you. Change the injector size in evoscan as well to match the scaling in your map.
plastus
Aug 4, 2015 07:59 PM
ybaba888
May 16, 2014 09:57 AM
babaz7
Apr 8, 2013 10:18 PM
unihappytime
Mar 8, 2013 07:50 AM
