re: ecuflash evo7 ecu
Old Jan 24, 2013 | 09:19 AM
wcassar's Avatar
hi all I m having an issue with the ecu flash, flashing an evo
7 ecu trying to modify the fuel map.
I have several questions to ask
Which graph shall i use? low or high octane? I am using normal octane fuel
how does the ECU recognise which map is active or deactive ?
I varied the low and also the high fuel map but no result on the dyno was
effecting
Only when i varied the 1000-1500 range effected the engine. (i made it too lean just to test it and the engine did not start at all, so the ecu is programing good)
If someone can help me i will be more than happy, because today I went on a dyno test bench and I paid money for no advance in bhp :/
Old Jan 24, 2013 | 10:59 AM
evo8426's Avatar
Take a look into this thread and it will help you learn how to tune.
https://www.evolutionm.net/forums/ec...-tune-evo.html
Old Jan 24, 2013 | 12:34 PM
todd6027's Avatar
It uses the high octane fuel and timing maps until ecu sees a certain amount of knock then it looks up low octane fuel and timng maps
Old Jan 25, 2013 | 01:34 AM
wcassar's Avatar
my result graph was after 3500rpm, getting richer till 8000rpms....final 10:1 AFR. The fuel map was leaned to a pont that the AFR reading should be almost 12:0 but this did not happen.
Could it be that I am using an Air flow sensor of an Evo3 gsr engine?
The ECU plugged in is that of an evo7......do they match or shall i replace it with an evo7 oem one? (I am running it at 18psi)
regards
Old Jan 25, 2013 | 07:17 AM
evo8426's Avatar
The AFR number in the map is an arbitrary number, it does not actually stand for the actual AFR the car is running. You must have a wideband to tune the fueling as to not be too rich or too lean.
Old Jan 25, 2013 | 08:20 AM
wcassar's Avatar
I have yes a wideband AFR meter and i am using in too.
The problem is that on dyno tuning even with a sofisticated wideband meter and also the same results came out.
Could it be that the MAF sensor is maxing out when using high boost? (18psi)
regards
Old Jan 25, 2013 | 08:23 AM
ecktt's Avatar
not even close
todd6027's Avatar
never had an issue with evo3 maf with 7 ecu some running 30psi ,what injectors ??
Old Jan 25, 2013 | 08:27 AM
wcassar's Avatar
I put the evo7 560cc pink ones
Is there a specified MAF sensor for an evo7 ecu? or they all match?
Old Jan 25, 2013 | 11:42 AM
todd6027's Avatar
evo7 ecu will work with any maf evo4 to evo9
is that better
Old Jan 26, 2013 | 09:08 AM
wcassar's Avatar
Did not understand well? em 4? so I have to change the MAF sensor from an evo3 one to an evo4 and over? If i understood well?
Old Jan 26, 2013 | 10:15 AM
todd6027's Avatar
no you dont ,it will work perfectly well with the evo3 maf thats is of course if it is scaled correctly . what do you have in ecuflash for maf size and what are the maf scalings
Old Jan 26, 2013 | 10:16 AM
stunt2's Avatar
as I've understand you have evo 7 ecu in evo 3 ?
there should be no problem running 3's MAF
just scale maf/injectors properly and you'll be good
Old Jan 26, 2013 | 10:24 AM
wcassar's Avatar
Yes stunt2 I have evo7 ecu and evo3 gsr MAF sensor. How should be the MAF scaling table than? as I have the evo7base map installed in the eue currently.
Old Jan 26, 2013 | 10:26 AM
wcassar's Avatar
I will chack tham and post them soon todd6027
