Evo scan problem after ecu flash update
Old Jan 26, 2013 | 09:47 PM
turbotoy's Avatar
Need some help with this please. Problem started with updated ecu flash.
Newest versions of both evo scan and ecu flash.
Tried several things but I could not fix
Old Jan 27, 2013 | 04:38 PM
richardjh's Avatar
EvoScan must use EcuFlash XMLs for its map-tracing functions... and it doesn't like something in those XMLs.
If you're not actively using those particular ROM ID XMLs, maybe rename them to ".xml_old" or something.
If you are using them, then you could try fixing up the XML definitions - to fix those errors. XML is a very tight spec, but some parsers are slack. I reckon EvoScan's parser dislikes something in the "new" EcuFlash's XML fileset.
Rich
Old Jan 27, 2013 | 09:11 PM
RS200Z's Avatar
In addition to what Richard has mentioned, EvoScan will also parse all other XML files and if it finds an error in any of them, (even though it's relating to other ECU ID) it may not work properly.
Here's what you can do, created a new folder and place ONLY the ECU ROM file and it's corresponding XML definition file in it and it should open up in EvoScan Map Tracing screen without any problems.
Old Jan 27, 2013 | 10:42 PM
turbotoy's Avatar
Okay got it to work with my backup XML files. Was just trying to get it to work with the new stuff.
Thank You!!!!!!!!!!!
mr.k
Jul 26, 2017 02:36 PM
4b11slayer
Nov 6, 2016 05:16 PM
4b11slayer
Nov 5, 2016 11:11 AM
Abdullah Gheith
Aug 26, 2016 02:46 PM
mosscar
Oct 23, 2015 08:55 AM
