EvoScan v2.9.0023 "load calculated" !!
Old Feb 2, 2013 | 08:30 PM
sound77's Avatar
Hi,
Why I keep getting this window every time a check on "load calculated" ?
injector scaling must preceed load cal
i.e move injector scaling above load cal !!
Now there is no display for injector scaling to move around ! so how to fix this ??
Thanks
Old Feb 3, 2013 | 12:46 PM
todd6027's Avatar
use 2 byte or 1 byte load , is there a number in injector scaling box , to the right of select ecu
Old Feb 3, 2013 | 01:42 PM
codgi's Avatar
Look at the parameters that the calculated load is using. For load to be calculated it requires those parameters to all be selected for logging as well as logged before the calculation to be done. Evoscan does this visually by ensuring that the order of items you see in the UI is how its logged.
Truthfully its an improvement that could be made to EvoScan. For any calculated value once the inputs for the calculations are selected to log, their visual placement shouldn't matter.
Fast_Freddie
Oct 30, 2023 01:56 AM
roni4g63
Nov 14, 2015 11:45 AM
Dynotech Tuning
Oct 2, 2013 03:39 PM
babaz7
Jun 23, 2012 10:01 AM
