Stock Rom vs Tephra
Stock Rom vs Tephra
need help deciding
aiming for 350 hp on 9 turbo, I have supporting mods
Stock Rom - I changed the load values to 20,40,60 etc to 360
should I do this instead if I want something basic to tune my car
Tephra - Im not really used to the new columns and I dont know half that stuff on the new rom vs the old rom I used before. If this is prefered what should I copy over from the stock rom to the tephra rom in order to tune for my goal?
need help would like to tune this week so I can get my car where I want it
Thank you
Thank you
Big maps are fine just way to many columns when trying to find octane map, duty cycle etc... I tried converting some stock stuff over and I couldn't really transfer things over due to different numbers and there was no percentages for accel enrichment.
Anyone have a link to tephra 5.1
Found link which rom for 03 evo 8?
not sure what you refer to about different numbers, but you transfer everything from your rom to the tephra rom. if your rom has a value and tephra is a percentage, then this is only a scaling difference.
its very easy to move over to a tephra rom, you just need to use the big maps translator for fuel and timing. as for the gear type maps, just make them all the same as a starting point.
cheers
cheers
