How change load on the table
Old Mar 2, 2013 | 09:43 AM
raza21_84's Avatar
I have 90550001 rom on the evo 7. The load area on the table is upto 300. The Turbo I have now will be hitting around 340 load. How do I scale/change this properly. Running on MAF. Using EcuFlash.
Posted from Evolutionm.net App for Android
Old Mar 2, 2013 | 12:33 PM
todd6027's Avatar
take out some of the lower load cells like 20 and 40 or 30 and 50 then move the corresponding fuel map values to the proper column add in 320 and 340 load at the end ,
you need to do the same with the timing maps and alternate maps if used
if needed send me the rom il change em and send it back
Old Mar 10, 2013 | 10:54 PM
raza21_84's Avatar
would I need to do anything on the XML?
Like this part
<scaling name="Load" units="%" toexpr="x*10/32" frexpr="x*32/10" format="%.0f" min="0" max="300" inc="1" storagetype="uint16" endian="big"/>
<scaling name="Load16" units="units" toexpr="x*5/8" frexpr="x*8/5" format="%.1f" min="0" max="120" inc="1" storagetype="uint16" endian="big"/>
Also do I need to do anything on Evoscan to LOG higher loads? I already have my XML in evoscan and am able to see Loads upto 300 on map tracer now.
I haven't started logging yet. Trying to learn as much as I can for now first.
Old Mar 11, 2013 | 07:04 AM
evo8426's Avatar
No you do not adjust the XML file, you adjust the actual load when you are looking at it in ecuflash.
Old Mar 11, 2013 | 12:47 PM
todd6027's Avatar
as said above attach the rom here or send the send it to me il rescale it and send it back il pm ya e mail address
Old Mar 12, 2013 | 07:05 PM
raza21_84's Avatar
You have mail
Boosted Tuning
Aug 26, 2023 10:14 PM
lancerrally45
Jun 15, 2016 12:25 PM
Seancj
Aug 24, 2015 08:43 AM
Octane Blue
Jul 10, 2014 05:02 AM
Ceddy
Jan 5, 2010 06:33 PM
