Rough idle after sensor swap and flash
Old Mar 2, 2013 | 06:39 PM
EvoIXPilot's Avatar
So, I installed a JDM MAP Sensor and did the edits on my Rom 94170715 provided by Evo8426. Works great in boost logging, no CEL or starting issue, but the idle seems a bit rough than usual, definitely noticeable. It was the same map with couple of values changed in the MAP Sensor section. What might've I done wrong?
Old Mar 3, 2013 | 08:10 AM
evo8426's Avatar
Have you changed the scalings in ecuflash by chance? There are a few that need to be changed. To do this you have to right click on the table in the left window pane of ecuflash. Where it says OMNI 4 Bar you need to change it to JDM 3 Bar.
Old Mar 3, 2013 | 09:40 AM
EvoIXPilot's Avatar
HEy thanks again. I'm trouble finding the first scaling pane, the MAP Sensor metadata table. I don't have one in the MAP Sensor subcategory. Is it just my ROM?
Old Mar 3, 2013 | 02:06 PM
Dynotech Tuning's Avatar
He isn't on speed density so none of those would affect idle. Log your EGR duty at idle, only PSI based boost control. If the settings are wrong, it may be opening your EGR valve at idle.
-Jamie
Old Mar 3, 2013 | 02:15 PM
evo8426's Avatar
I keep forgetting that not everyone is running speed density, my bad.
Siluck2
11
Apr 11, 2016 06:06 PM
10isace
Nov 21, 2014 11:38 AM
JTCB
May 31, 2014 07:22 AM
bayaraa524
Dec 29, 2012 02:47 PM
