Evo 7 Maxed out injectors and weird power graph?
Old Mar 4, 2013 | 09:40 PM
unihappytime's Avatar
Hi Guys,
Check out my log last night, mods below, stock apart from bigger inter-cooler and a Tomei M7960 turbo.
The power graph looks week and I got some high amount of know near the top end, could this be due to the injectors being maxed out?
I get a few jerks, like a fuel cut after 6k RPM.
my boost controller says I max at 124 kpa, that was around 6.5k RPM.
The first pull was from 3rd 2k to around 7k followed by a 4th gear pull to around 6k.
I DONT have wideband installed yet, so please ignore that data.
Any comment on how to improve the car for a better DD?
Old Mar 4, 2013 | 10:27 PM
BEKevo's Avatar
Originally Posted by unihappytime
Hi Guys,
How are you logging AFR, if you have no wideband? You need to know AFR, to diagnose IDC % irregularities. Also you shouldnt be touch the fuel map, without AFR's being logged.
Old Mar 4, 2013 | 11:33 PM
foxbat's Avatar
With such larger turbo, you need larger injectors (1000cc) & Walbro 255 fuel pump (or bigger). you definitely need a full re-tune & you should get some neat power out his turbo even with pump fuel (around 26psi - 1.7/1.8bar).
I'd also recommend that you install aftermarket head studs, so, the engine won't leak @ higher load levels.
Old Mar 5, 2013 | 02:40 AM
Thanks for the tips guys!
Since I don;t have a wideband, I won't touch the ECU, so that will be on my list of to buy things next.
I just logged the car
apart from that new injectors and a fuel pump should help me see better result?
but in HK i don't trust the cowboy tuners here, and I have read but not too familiar with injector scaling, let alone tuning to take this on my self.
So would putting back a stock turbo help my figure better?
the spool is slow and late, max spool is around 5k @120~ kpa
Old Mar 5, 2013 | 02:44 AM
philr8's Avatar
Heres a Evo 6 I mapped with a Tomei M7960 turbo, PTE 880cc injectors, 26psi boost and stock engine, crap NZ 95 octane fuel (same as US91 I believe)
This should give you an idea of what to aim for
Attached Thumbnails Evo 7 Maxed out injectors and weird power graph?-tim-boost.jpg   Evo 7 Maxed out injectors and weird power graph?-tim-evo6.jpg
Old Mar 5, 2013 | 05:10 AM
Thanks Philr8!
Looks like this turbo has a tendency to reach max spool up top.
what intake and exhaust dose it have?
Mine has a ARC air box and stock exhaust with cat, on HK gas 98 ron I think.
I would prefer a faster spooling turbo for street car, so back to a stock turbo would be ideal, at least no need to tune, can run to around 280 hp.
Then I can slowly add a nice exhaust, the new injectors, and finally a HKS GTII?
Old Nov 9, 2013 | 02:43 PM
Nimpoc's Avatar
Happytime, did you ever get this sorted out?
If I were you I'd sell:
UR pulleys, HKS oil cooler, Tomei thermostat kit, HKS EVC
And go back to stock on all those parts.
Take that money and get a fuel pump and nice exhaust system to reduce backpressure so the turbo can spool-up and make some power. Don't worry about the injectors as stock ones are good 'till 350+WHP. Lastly get the wide-band and have one of the good US tuners do a remote tune for you. The car will make tons more power everywhere and feel much more responsive to boot.
GL
Old Nov 10, 2013 | 08:57 PM
GL
Hi Mate,
I'm on to it, part of my problem was cylinder 1 and 2's coil was not plug on fully, this helped with the bucking at high speed.
I have now changed to Tephra 90550701 V7, make the drive a bit smoother.
Got a AEM WB sensor, waiting for my Tomei front pipe and then will install the sensor.
Will boost leak test, then I am ready for a basic tune.
Next on the horizon, injectors and maybe cams and TBE.
Old Nov 26, 2013 | 02:11 PM
burgers22's Avatar
I think it'll be running lean, especially if you have the stock fuel pump, my 7 ran about 17.2 ms IPW with an 80 series.
Old Nov 26, 2013 | 10:27 PM
That's what I was afraid of, but my mechanic says by the sound of the pump, it sounded like a bigger than stock pump.
Anyway my initial tune will be around stock level boost and power, until I upgrade my fuel system, I will get a new pump then.
I aim for a fast spooling 400WHP, 3XXWTQ fun street car.
By the way, for that kind of power, do I need to replace my stock clutch disk after the tune?
I don't drive it hard much, only once a while on highways, and a few times a year on twisty mountain roads.
Boosted Tuning
May 23, 2025 01:08 PM
vortico
Jan 20, 2012 06:46 AM
riceclown
Oct 4, 2010 04:43 PM
sgplancer
Sep 3, 2004 05:53 PM
