Test pull - how does it look?
Old Jan 19, 2012 | 04:23 PM
vortico's Avatar
Hey all,
Did a test run near my house today only from 2k to 6kish to get an idea of where I stand before I start getting tuned. Just wanted to get some folks impressions on how the car is currently. Here is my list of mods:
  • mail in flash
  • buschur intake
  • buschur turbo back exhaust with hfc and bullet muffler
  • Suspension mods.
I realize I forgot to modify the JDM 3bar sensor to my local pressure, so I think it should be around +1 psi to what the graphs say. (4000ft)
How do you read these to know when the turbo is spooled? pretty much when it hits max boost so ~3500 in my case?
Old Jan 19, 2012 | 06:46 PM
Raptord's Avatar
What fuel is this on?? That's a lot of timing at peak torque for pump gas. Fueling needs some work too.
Old Jan 19, 2012 | 06:50 PM
vortico's Avatar
OOops forgot to put that. 91 octane 3500ft elevation. Yeah the tune needs serious work and is going to be done fresh soon
Old Jan 19, 2012 | 07:19 PM
grim~'s Avatar
thats hard to read that log,you should put the excel file in a folder then zip that folder and upload it to evom.
Old Jan 19, 2012 | 07:25 PM
Vigman's Avatar
I agree it is a way too much timing @ peak torque.
I will add some timing before 3000 and progressively go down to 3-4 around 3500RPM.
Add some timing after 4000 RPM.
Regarding AFR, you should lean before 3500 and make it smoother in the 5k range.
Since you live @ 3500ft high, remember to recalculate your load before working on the map to be in the right cel. I also recommend to stay <11.0 AFR after 5000RPM cause of the altitude.
Hope it hels,
Cheers
Old Jan 19, 2012 | 07:26 PM
Vigman's Avatar
Just rename the extension file from .txt to .csv and open it with Excel!
Old Jan 19, 2012 | 07:48 PM
Raptord's Avatar
Hope it hels,
Cheers
Why would you run richer because of altitude? Personally I see no reason to go under 11.0 AFR.
Old Jan 19, 2012 | 08:34 PM
Vigman's Avatar
Hello my friend from Quebec!
I agree 11.0 is right (I should have wrote <=11.0:-)
I won't go leaner because I have observed that @ same AFR, EGT is going up with altitude (probably cause of lower air density)
Baro compensation table on the ECU is not working correctly upper 4500ft, I know our friend is @3500 but without EGT, I will recommend to go safe.
That's my point of view.
Cheers
Old Jan 20, 2012 | 06:44 AM
vortico's Avatar
Thanks everyone for your help =). I'm quite eager to get the car retuned as I know at least my mivec table is still stock.
I tried to upload the file as a csv but I think I remember the forum rejected the file type (although at that time I also had another 80k of commas I had not noticed a the end of the file so maybe that was the issue lol).
Old Jan 20, 2012 | 06:46 AM
Raptord's Avatar
You can't upload csv's. Good call on uploading as a txt, easier to rename the extension back to csv rather than unzipping it.
qu evox
133
Dec 2, 2020 08:39 AM
joonvang
Jun 2, 2016 03:46 PM
ddejaege
Jul 27, 2014 06:59 PM
AcePitcher11
13
May 7, 2013 08:23 AM
boomn29
Sep 14, 2012 08:35 AM
